Alternatives to Nissin Caliper
As title ,are there any alternatives to using a Nissin Caliper on a ScootRS set up ?
https://ilambretta.co.uk/forum/
coaster wrote:Are you looking for something less vicious Peach? The SIP calliper on my jet works very well but as Martin said, would need a new calliper bracket.......job for CS?
Knowledge wrote:I would have thought that if you are prepared to build a new caliper bracket, then you can have a choice of calipers. I've a four pot caliper from an R1, but the brake is not the RS type.
rossclark wrote:Is that on the zip wheel? Or a custom carrier?
foremanbob wrote:Honda CB125
