Alternatives to Nissin Caliper
Postby Angry Bloke » Sun Mar 01, 2015 7:54 pm
As title ,are there any alternatives to using a Nissin Caliper on a ScootRS set up ?
Angry Bloke
Re: Alternatives to Nissin Caliper
Postby rossclark » Sun Mar 01, 2015 8:05 pm
You'd need to find one off a bike that was for the same diameter disc and that mounted with the same bracket / bolt spacing on the carrier.
I think that would be a bit of a challenge TBH.
I'm sure someone might have said on the SE site what the bike it is off was.
Postby Knowledge » Sun Mar 01, 2015 9:51 pm
I would have thought that if you are prepared to build a new caliper bracket, then you can have a choice of calipers. I've a four pot caliper from an R1, but the brake is not the RS type.
Postby coaster » Sun Mar 01, 2015 10:39 pm
Are you looking for something less vicious Peach? The SIP calliper on my jet works very well but as Martin said, would need a new calliper bracket.......job for CS?
Postby rossclark » Sun Mar 01, 2015 10:46 pm
Is that on the zip wheel? Or a custom carrier?
Postby foremanbob » Sun Mar 01, 2015 11:25 pm
Honda CB125
foremanbob
Postby Angry Bloke » Sun Mar 01, 2015 11:26 pm
coaster wrote:Are you looking for something less vicious Peach? The SIP calliper on my jet works very well but as Martin said, would need a new calliper bracket.......job for CS?
It's for Cheggers ,he's just looking for that looks better TBH , as part of his GP spruce up .
Knowledge wrote:I would have thought that if you are prepared to build a new caliper bracket, then you can have a choice of calipers. I've a four pot caliper from an R1, but the brake is not the RS type.
Good point Martin but I think he wants to use what he has - but thanks :D
rossclark wrote:Is that on the zip wheel? Or a custom carrier?
No just a normal ScootRS set up
Angry Bloke
Postby Angry Bloke » Sun Mar 01, 2015 11:27 pm
foremanbob wrote:Honda CB125
Thanks :D
Angry Bloke
