RB20 Piston choice
RB20 Piston choice
Postby gaz_powell » Sat Feb 07, 2015 5:43 pm
I have a knackered barrel on the shelf and am looking to steel line it and built a spare motor (or this will probably be the seed to build another bike !)
Looking at piston options am I right in thinking that a Yamaha blaster 200 was the piston used in the kit ?
Cheers Gaz
Re: RB20 Piston choice
Postby dscscotty » Sun Feb 08, 2015 7:55 pm
Hi Gaz,
ye that's right its the Yamaha YFS 200 -Blaster-although you can use other pistons.(AF now use wossner equivalent) I've had couple of RB200 cylinders lined the last one used a DT piston and has proven to be very reliable. you could also use RD pistons from 64mm and take advantage of over-sizes available, however you would but loose a few cc's. Be careful as the liner is very delicate at 66mm.
Scotty-DSC
Postby gaz_powell » Mon Feb 09, 2015 1:03 pm
Cheers Darren
I like the idea of the RD to leave some meat on it - the loss of cc from 66 to 64mm will be minimal
Gaz
Postby soullad » Mon Feb 09, 2015 2:17 pm
Aye, and at Mitaka type prices the RD piston is well worth it. You could get a spare, which is what the liner is really all about. Should you get a problem out on the road, you might be able to clean it up as best possible, fit a new piston and go again. With Nicasil thou, you are bolloxed :(
soullad
Postby LateAgain » Tue Feb 10, 2015 11:54 pm
Where would you be looking to get it lined Gaz? I've got the same sat on a shelf.
LateAgain
Postby gaz_powell » Wed Feb 11, 2015 8:53 am
Paul
Fahron Engineering in Hucknall Notts
He did my TS1 barrel and head for a Yam IT 175 (66mm) - lovely job but you cant rush him !!
But i know a few people who use these http://www.pjme.co.uk/acatalog/Cylinder ... eving.html
Gaz
