150 to 200 studding
150 to 200 studding
Postby itisgonnarunproperly » Fri Jun 06, 2014 11:17 am
Good to be back firstly :D My Li Special is now on road and being run it, slowly but surely at w/e's, I'm already thinking of building another engine, I have a Perfect 150 S3 1963 casing that I bought last month, has anyone had the conversion from a 150 to a 200 studding done, and how much did it cost? Is it worth the cost or should I focus on getting a small block conversion barrel etc?
Re: 150 to 200 studding
Postby carlos fandango » Sun Jun 08, 2014 12:15 am
Oiltek in barnsley do them £145 ish afaik , i havent had one done though .......yet :)
carlos fandango
Postby Knowledge » Sun Jun 08, 2014 1:01 pm
The best 150 casings are the 200 casings that were machines to 150 size. These measure 95mm from top to bottom across the mouth. 150 castings are 90mm across (I think these dimensions are correct).
Using one of the 200 casting 150 casings means you get more gasket face to work with, but the same can be achieved on a standard 150 casing, but it required extra welding. Of course, the 150 casing can be used as is with a reduced gasket face if your intended barrel is relatively standard.
I like the look of Oiltec's work. I've seen the finished item at Wicksteed, and the video on You Tube, and it looks a quality solution. I have a 200 casting/150 casing already welded up but I can't decide whether to send it to Oiltec or my usual supplier, CS Engineering at Norwich.
Postby carlos fandango » Sun Jun 08, 2014 11:07 pm
^^ yep ive got two done :D
One on ebay at the moment
carlos fandango
Postby carlos fandango » Sun Jun 08, 2014 11:09 pm
carlos fandango
