LI 150 Pacemaker
LI 150 Pacemaker
Postby col1968 » Thu Jun 05, 2014 9:20 pm
Hi there what are peoples opinions on this gearbox.Thanks
col1968
Re: LI 150 Pacemaker
Postby petemaisey » Thu Jun 05, 2014 10:02 pm
I love it. It has a nice close set of ratios. However you don't get any thing for nothing. I'm using it in my iron barrel 225 Gp with a Clubman and 22 Dellorto through a standard airbox. It achieved 71.4mph on the David Blyth mad mile. The drawer back is that to get a good top gear ratio means you have a high first gear. I find I have to slip the clutch a little more than normal in order to get going.
Pete
petemaisey
Postby col1968 » Fri Jun 06, 2014 6:23 pm
Thanks for your reply Pete, i run a Mugello186cc Chiselspeed tuned,28mm Dellorto, Ancillotti pipe. Its just i have to give it some throttle in 3rd before i go into 4th or else she bogs down.Col
col1968
Postby petemaisey » Fri Jun 06, 2014 6:47 pm
I should have said I am using GP reduction, 18/47.
Pete
petemaisey
Postby Jazzy b » Fri Jun 06, 2014 7:30 pm
Got one in my sx running stage 4 af 175 got to say it flys compered with same set up on my s2 but the 2 is laden with accessories 8-)
Jazzy b
Postby Captain Pugwash » Fri Jun 06, 2014 7:56 pm
Just removed a Cyclone 5 speed to put a Pacemaker gearbox in my TS1
Captain Pugwash
Postby torquewrench » Fri Jun 06, 2014 8:13 pm
Captain Pugwash wrote:Just removed a Cyclone 5 speed to put a Pacemaker gearbox in my TS1
Not intended to be a silly question, but why ?
torquewrench
Postby Adam_Winstone » Sat Jun 07, 2014 10:42 am
^... that was my first thought/question too.
Postby col1968 » Sun Jun 08, 2014 10:15 am
i was thinking of changing from a LI150 Pacemaker to an Italian LI150 but, from the response from you gents, i am sticking with the Pacemaker.Thankyou.
col1968
Postby G.I » Tue Jun 10, 2014 12:57 pm
Is the "stronger" third gear a straight replacement for the "weaker" one or are there other factors I haven't thought of yet?
G.I
