Temperature senders
Can any electronic type wizard tell me whether there's any reason why the temperature senders from the SIP / KOSO speedos couldn't have the connector changed and be used on the Trailtech Vapor and TTO gauges ? I have these gauges on several scooters and find them accurate and reliable with the exception of the senders which are quite flimsy and easily broken.
These cost around £30 to replace and the complete TTO unit is only £40. The SIP /KOSO senders are £16 and come with 4 spare detachable rings , the whole thing looks stronger as well. The idea is to put the right connector onto the SIP / KOSO sender and connect to the Trailtech units .
Will this work ??
Steve
Will this work ??
Steve
