Cylinder hone
Cylinder hone
Postby jonno » Sat Nov 08, 2014 7:46 pm
The cross hatching in my steel lined TS1 has been worn smooth in some areas,and some scuff marks on cylinder and barrel.Would I get away with a hone of the cylinder,or is it new piston and hone time?
jonno
Re: Cylinder hone
Postby rossclark » Sun Nov 09, 2014 12:20 am
Check your ring gap and piston to bore clearance is the only way to know for sure.
