IMOLA 186
IMOLA 186
Postby Darlospeed » Fri Nov 07, 2014 9:45 am
Can I ask what carb & set up, pipes and gearing people are running on Imola 186? Just about to stick one in a small block.
Darlospeed
Re: IMOLA 186
Postby piskie » Fri Nov 07, 2014 6:23 pm
It can be what you want it to be its a mini ts1 with a 28ml dellorto and a clubman will pull tv175 sx 200 gearing and a 16 tooth front with a jl or devtour leave with a 15 tooth front
piskie
Re: IMOLA 186
Postby Toddy » Fri Nov 07, 2014 8:36 pm
Built one for one of our lot, as Andy says mini TS , 30mm delly , jl3 pipe li150 Spanish box (Graham's choice) 46x16 ok on flat struggled up hills (up and down box ) better with Italian LI , 5 plate clutch , mec crank , little monster :D
Re: IMOLA 186
Postby corrado » Fri Nov 14, 2014 10:36 pm
The kit is designed to rev high, don't spoil it by trying to turn it into a tourer. Short gearing and revvy exhaust works great.
Mine ran 5.4 final drive, scootrs exhaust and TMX27 Mikuni. In a foolish attempt to turn it into a motorway tourer I dropped the gearing to 5.00 and fitted a JL3 and it became a plodder that spent half it's time in 3rd trying to get back into the power band.
corrado
Re: IMOLA 186
Postby bazza3004 » Sat Nov 15, 2014 4:13 am
Li 150 box franspeed race 30 delly 60/110 crank. Im 17 st and it pulls 4th on inclines pretty well. I have played with the port timings though.
bazza3004
Re: IMOLA 186
Postby Ianh5 » Sun Nov 23, 2014 8:37 pm
I ran an imola with a 30 mm dellorto phbh, Fat Mamba exhaust with a pacemaker gearbox. Great kit
Ianh5
