Sip Counter Digital sensor externe
Postby LambrettaBerty » Wed Nov 05, 2014 5:44 pm
hello,
I'm new to the forum, I'm from belgium.
I'm trying to mount an external sensor for SIP counter KOSO SA 07
Someone is already using this system?
Could you take a picture of a face so see or look exactly the sensor.
With this active sensor, I think that we should not put magnets?
Thank you for your answer.
Berty
LambrettaBerty
Re: Sip Counter Digital sensor externe
Postby carlos fandango » Wed Nov 05, 2014 10:48 pm
This is how I mounted one on a pm disk. Its similar on a scootRS type.
carlos fandango
Postby foremanbob » Thu Nov 06, 2014 11:10 pm
LambrettaBerty wrote:With this active sensor, I think that we should not put magnets?
Berty
Berty, the Sensor will pick up on bolt heads, but I used a single magnet (with a blob of superglue underneath; to be sure) and had great results.... Fitted sensor similar to above....
foremanbob
Users browsing this forum: Baidu [Spider], Google [Bot] and 84 guests
