Gearbox choice
Gearbox choice
Postby jonno » Thu Nov 12, 2026 10:18 am
I've got TS1,with MB box pipe. What would be the choice of gearbox, 5 speed or GT ?
Currently running GP200 box
jonno
Re: Gearbox choice
Postby hullygully » Thu Nov 12, 2026 10:43 am
Indian GP preferred over Italian GP bud.
A 5-speed box gives you the grin factor 8-)
Re: Gearbox choice
Postby Rich Oswald » Thu Nov 12, 2026 12:38 pm
hullygully wrote:Indian GP preferred over Italian GP bud.
+1
Re: Gearbox choice
Postby ROClarke » Thu Nov 12, 2026 1:38 pm
I don’t see the point of a 5 speed if you are running a box exhaust.
Also you have not mentioned your front and rear sprocket size.
ROClarke
Re: Gearbox choice
Postby Rich Oswald » Sat Nov 14, 2026 11:13 am
You won't know the benefits until you have tried one tbh.
Re: Gearbox choice
Postby gaz_powell » Sun Nov 15, 2026 3:00 pm
I'm a big fan of the SIL GP200.
Got it in all my TS1 200 and 225 with 19*46
Re: Gearbox choice
Postby Jeff t » Sun Nov 15, 2026 10:53 pm
Starting a 200 build although not decided which kit yet, I've a Li150 S2 gearbox in a Small block muggello which works great but if i decide on 5 speed which one AF or is the MB one worth the extra?
Jeff t
Re: Gearbox choice
Postby dickie » Mon Nov 16, 2026 6:06 am
gaz_powell wrote:I'm a big fan of the SIL GP200.
Me too, especially from a value perspective. Although I have a casa 4 speed close ratio in my rt230 reed and that's very similar, albeit with smoother gear changes. Not too expensive, around £300 from memory. There are obvious advantages of a 5speed, but less pronounced on a motor with a wide spread of power. Easier to build as well.
Re: Gearbox choice
Postby hullygully » Mon Nov 16, 2026 10:58 am
Jeff t wrote:Starting a 200 build although not decided which kit yet, I've a Li150 S2 gearbox in a Small block muggello which works great but if i decide on 5 speed which one AF or is the MB one worth the extra?
I've one of the first Broady boxes from years ago, mates have the AF's version, the final ratios are almost the same, plus still a 5 x speed, so I'd push you the AF's way, same-ish product, but cheaper 8-)
Re: Gearbox choice
Postby Rich Oswald » Tue Nov 17, 2026 9:07 am
+1
Re: Gearbox choice
Postby shamrockexpress » Tue Nov 17, 2026 3:01 pm
+1
Sometimes Simplicity equals Reliability
this has been tried and tested since the 80 s..............
shamrockexpress
