Hi
I have a Cyclone 5 speed gear box, and was experiencing difficulty selecting gears, so stripped it down
I noticed that the layshaft had some type of corrosion so decided to replace with a new Casa layshaft
https://postimg.cc/gallery/9MQCp4t
I fitted the new layshaft and have torqued up with rear hub
However, fitting the endplate locks it up, even with smallest shim (0.8mm)
I don't know whether it's the rear bearing (which I haven't replaced) or the endplate is warped??
I'm not sure what I should do next
