Tinos sito made ancillotti exhaust
Posted:
Wed Aug 19, 2026 10:21 pm
by gaz_powell
Any real world experience..on a Monza 200?
Ive got a 48mm AF clubman with an AF made oval flange, but not to sure.
Gaz
Re: Tinos sito made ancillotti exhaust
Posted:
Sat Aug 22, 2026 7:10 am
by dickie
I used a sito one on a tuned gt186 that I had a few years back and it performed quite poorly.
It was swapped for a bgm v3 which raised power by about 50%!
Personally I'd have thought the 48mm would work well on a monza. The larger tailpipe will stop it gassing up and overheating too
Posted:
Sun Aug 23, 2026 12:35 pm
by gaz_powell
Cheers Dickie
Im going with the 48mm clubman... U bend has been chromed and the pipe heat resistant powder coated.
Problem for me is the BGM is made by BGM....as with anything "made" by them, they won't be on my bikes..
Possibly the SIP version, but let's see how the AF goes..
Posted:
Tue Aug 25, 2026 6:04 am
by dickie
My BGM split across several lines in apparently unstressed areas. Dale Anderson's blew a hole in the side on the way to Lincoln and Newark rally.
