GT186 Reed servicing
Postby TrackTen » Wed Jun 17, 2026 8:34 am
I know there are a few GT186 fans here so I hope someone can answer this
How easy or difficult is it to get the reed block out of an engine that is still in the frame should I need to do it in the field
TrackTen
Re: GT186 Reed servicing
Postby Covboy » Wed Jun 17, 2026 8:53 am
hello - relatively simple - i've done this before - remove rear shock (and bump stop if possible) to lower the cylinder end.
4 x allen key bolts. The reed block has small cross has screws securing the petals
Postby Storkfoot » Wed Jun 17, 2026 1:32 pm
As above but not all Allen keys can get access. I cut one down to fit. It had a long handle part too which made it easy to turn.
