AF 5speed shimming
AF 5speed shimming
Postby Den08 » Fri Mar 13, 2026 12:59 pm
Af 5speed box Shimming.
Is the 1,2 shim to small to fit under end plate as Af say in their blurb 1,4 is the minimum and 2mm is the max, the 1,2 is a good fit with clearance on the feeler gauge, the 1,4 is to tight, if a 1,2 is to small what is the consequences ?, i'm trying to understand the reasoning i have the bearing shims to move the gear stack out towards the hub, also i have the cambridge 0.5 shim for the end plate but the 1.2 is a good fit without all the faffing about.
All comments from you more knowledgeable people would be appreciated.
Den08
Re: AF 5speed shimming
Postby Toddy » Tue Apr 07, 2026 11:19 pm
Den08 wrote:Af 5speed box Shimming.
Did you go with the 1.2 ? If so how’s it going, I’ve never gone under the recommended 1.4
Postby Den08 » Thu Apr 09, 2026 7:05 pm
Ended up putting a shim under hub bearing 0.2 from Torbay lambretta and ended up with a 1.5 main shim, done about 130 miles without issue so far.
Den08
