Gori ignition kit
Gori ignition kit
Postby superhooper » Sat Jan 24, 2026 12:54 pm
Hi peeps, are any of you using the Gori ignition kit? If so what are your opinions?
Super
superhooper
Re: Gori ignition kit
Postby Knowledge » Sun Jan 25, 2026 3:08 pm
Why has the Gori ignition kit ignited your thoughts Super?
Postby superhooper » Mon Jan 26, 2026 10:58 pm
Cost compared to other kits. no pick up to fail. Earthing issues with vape & looks like even a simpleton like me could fit it.
superhooper
Postby Knowledge » Mon Jan 26, 2026 11:19 pm
It is cheaper than the Casa kit, but more expensive than VAPE, based on my limited research.
Whilst the traditional six pole Ducati stator has LT coil and pick-up issues, whilst all others do not (as far as I am aware).
Is the GORI easier to fit? I like that fact that the GORI kit includes brackets but it appears that the easiest to fit is the Casa (no timing issues)
What concerns me most about the GORI is the four coils which look so similar to those on the Varitronic, which has a particularly poor lighting output (watts). Is the GORI output better?
A grown-up will be along shortly to answer some or all of these questions.
Postby corrado » Sun Jul 26, 2026 1:59 am
Did you go with the Gori kit?
corrado
Postby superhooper » Sun Jul 26, 2026 3:39 pm
No i ended up putting a rewired stator on. Unfortunately the flywheel broke in two half way to Austria! Doh!
superhooper
