Soldering kit to rewire a stator.
PostPosted: Fri Sep 26, 2025 9:33 pm
by Storkfoot
For many years, I’ve survived on a Draper 20w soldering iron. It still works but as I need to completely rewire a stator plate, I have been looking online for a more powerful replacement.
My head’s frazzled looking at them all :!:
Can someone recommend one that will do what I need please?
Oh, and do I need one of those “solder sucker” devices or are they no better than the wick method of removing old solder?
Re: Soldering kit to rewire a stator.
PostPosted: Sun Sep 28, 2025 8:35 am
by dickie
Solder suckers are excellent, worth buying to do a nice job. I'll bet you can get one for peanuts on ebay etc
I'm not on the tools anymore, apart from occasionally,but when I was, I used one all the time.
I'd also recommend a brass brush to clean surafaces before soldering, oxidised copper can be a nightmare to solder.
https://share.google/w28TA3y2br4EyGsez
That's a bargain but you'll need change the plug to uk type.
PostPosted: Mon Sep 29, 2025 7:51 am
by Storkfoot
dickie wrote:Solder suckers are excellent, worth buying to do a nice job. I'll bet you can get one for peanuts on ebay etc
Thanks very much for that response. You are right that solder suckers are cheap on eBay :)
PostPosted: Mon Sep 29, 2025 12:10 pm
by al pushpak
Storkfoot wrote:For many years, I’ve survived on a Draper 20w soldering iron. It still works but as I need to completely rewire a stator plate, I have been looking online for a more powerful replacement.
We use the "Weller" brand soldering irons at work which are 90w & are perfect for repairing stator plates as I've repaired a couple of mine in the past using the work one's, & yes, a solder sucker is a good idea too.
PostPosted: Mon Sep 29, 2025 7:43 pm
by L111amo
I use a snap on gas pencil type soldering iron, never let me down
PostPosted: Wed Oct 01, 2025 6:03 pm
by Fast n Furious
Likewise, I use my 40 year old Weller 90W iron for such purposes. A small iron isn't big enough and will likely create a dry joint. Always make sure that your iron tip is tinned up and your wires are perfectly clean. A little brick acid can help here. I would also recommend using some isopropyl alcohol to neutralise the solder flux remnants afterwards.
PostPosted: Fri Oct 03, 2025 7:25 am
by Storkfoot
Thanks for all the replies. I have ordered a cheap 90w set off eBay with temperature adjustment and solder sucker. Whilst I do use a soldering iron quite a bit, to trim cables mainly, I doubt I would get the use out of an expensive set.
I’ll let you know how I get on with the stator. The stator I am going to rewire has multiple exposed wires and looks pretty sorry for itself. However, yesterday I checked the readings and they are all good.
