Avanti ST / GP panel unclipping
PostPosted: Thu Feb 27, 2025 12:38 pm
by Leotech
I just fitted an ST version with the end can to my GP, first bump I went over the tail can bracket unclipped the panel and if it wasn't for my cat like reflexes catching the panel it would have been down the road. It wasn't any big pot hole either, it was a small trench like thing. It happened about 2 miles into the first test!
Has anyone come up with a solution for this? I've not really looked yet but before I start just thought I'd ask.
Re: Avanti ST / GP panel unclipping
PostPosted: Thu Feb 27, 2025 9:24 pm
by Toddy
Never heard of this before , is your rear shocker ok ?
PostPosted: Fri Feb 28, 2025 7:57 am
by Leotech
Shocks ok but it’s only an Escort or similar. Might try a s2?shock for starters.
PostPosted: Fri Feb 28, 2025 10:53 am
by hullygully
The tail can goes under the kick start, the tail can brkt hangs down off two of the far west casing studs, so in reality the exhaust shouldnt cause you any problems :?
PostPosted: Mon Mar 03, 2025 6:09 pm
by tonytoolbox
had the same problem as you ,same pipe ,same bike found that my shock was not set correctly [protech shock] after changing settings all fine
PostPosted: Tue Mar 04, 2025 9:38 pm
by Mikedale
same happened to me
original paint panel down the road
removed the tailcan bracket so it just held on with spring
PostPosted: Thu Mar 06, 2025 12:25 am
by Leotech
I got a shock with adjustable pre load thread and wound it all the way down, The shock wont travel far enough now to unclip the panel even when I press hard on the back end.
I still need to go and hit some big holes I know locally and hopefully not loose my panel.
PostPosted: Thu Mar 06, 2025 4:14 pm
by Covboy
if you remove the rear shock completely and let the back end down so that mudguard sits on the tyre, does the panel / bracket foul?
PostPosted: Sun Mar 23, 2025 10:28 am
by Leotech
Covboy wrote:if you remove the rear shock completely and let the back end down so that mudguard sits on the tyre, does the panel / bracket foul?
Yes,
PostPosted: Thu Oct 08, 2026 7:38 pm
by jonoy
Did anyone find a permanent solution to this issue
as the same thing has happened to my GP.
