Varitronic starting issues when hot
Postby Jeff t » Sun Dec 08, 2024 10:00 pm
Anyone had issues starting when hot, i have checked everything fuel related, carb, reeds, even pressure tested thinking electronic issue. Set up old version Imola, phbh 30mm , franspeed exhaust.
Jeff t
Re: Varitronic starting issues when hot
Postby Rich Oswald » Mon Dec 09, 2024 10:23 am
Jeff t wrote:Anyone had issues starting when hot, i have checked everything fuel related, carb, reeds, even pressure tested thinking electronic issue. Set up old version Imola, phbh 30mm , franspeed exhaust.
Are you using an air filter of any sort?
Postby Jeff t » Mon Dec 09, 2024 8:59 pm
No runs open mouth
Jeff t
Postby gp200ts1 » Mon Dec 09, 2024 10:52 pm
Rings worn?
gp200ts1
Postby hullygully » Tue Dec 10, 2024 11:18 am
stator readings when cold & then when engines hot would help bud
Postby Rich Oswald » Tue Dec 10, 2024 12:16 pm
gp200ts1 wrote:Rings worn?
+1
Postby Jeff t » Tue Dec 10, 2024 11:02 pm
Its not done a lot of miles, is there any test i can do without taking the headoff, compression test? Only not done one before.
Jeff t
Postby Fast n Furious » Wed Dec 11, 2024 1:34 am
Jeff t wrote:Its not done a lot of miles, is there any test i can do without taking the headoff, compression test? Only not done one before.
You can use one of those typical £15 Fleabay automotive compression tester kits.
These kits typically use an M14/M10 plug to PCL adaptor. This adaptor then screws onto the gauge hose (where the one way valve is.) The usual problem here is that there is insufficient room to click the PCL fitting together because the cable guide that's connected to the choke lever, gets in the way. :x
Be aware though, that in effect, the adaptors actually raise the volumetric capacity of the combustion chamber slightly. So, the compression reading will show around 5% lower than it actually is. Not much I know, but hey ho. At kick start speed I would expect a reading of 65PSI or better. ( remember to keep the throttle open to allow the engine to breath!)
Don't be tempted to use the extension hose adaptor that comes with these kits because these will significantly increase the effective compression volume resulting in a dramatic incorrect low reading!
Postby Jeff t » Sat Dec 28, 2024 6:12 pm
I bought a compression tester but couldnt fit without the rubber hose so decided to strip down and check the rings anyway. The piston was pretty clean with hardly any marks past the rings but that might reflect how little i have used it since it was last stripped down.
Measured the ring gap and its about 0.43mm on a 64mm piston which reading Sticky’s book doesnt seem that bad, so now not sure if to rebuild as is or fit new rings. Any thoughts.
Thanks.
Jeff t
Postby Fast n Furious » Sun Dec 29, 2024 1:36 am
.25mm (10 thou) would be the normal gap for 64mm new rings.
Postby Jeff t » Sun Dec 29, 2024 9:10 am
Thanks new rings it is then.
Jeff t
Postby Adam_Winstone » Sun Dec 29, 2024 5:21 pm
But I don't expect a 0.43mm ring gap to be related to your starting issue as, like you noted from Sticky's manual, that is far from worn out.
Postby Jeff t » Sun Dec 29, 2024 9:18 pm
Yes and looking on Cam lam website it says minimum ring gap 0.3mm and max 0.7mm for Imola small bloc so still not sure !!
Jeff t
Postby Adam_Winstone » Mon Dec 30, 2024 1:01 am
You say that it's not done that many miles... could it be as simple as getting to know its starting requirement when hot?
I ask this as a pal of mine, who has decades of Vespa riding experience, was going on about how his Lambretta was a poor starter from hot. We then ended up at the petrol station together and I then witnessed kick, kick, kick, "It's not starting again now that it's hot."
Clearly the bike was flooding so I asked him if he always turns his fuel on before starting, to which YES was his answer. I told him that he should try starting with his tap OFF as he'll have a full float bowl already and that he might find it starts better without turning the fuel on. I had also noted that he had a tendancy to turn the throttle whilst kicking.
Rather than letting him replace the plug with a dry one, his usual fix, I asked him for a go, turned his fuel off, kept the throttle closed and it fired up within a couple of kicks. A change of technique was all that it needed.
I'm not trying to teach anyone to suck eggs here, just illustrating how a change of technique can make all the difference, especially when hot starting.
It seems as though you've covered most other things... but double check that the choke cable has enough play to close off 100% then in the off position, which is a common problem that can cause hot start issues.
Good luck.
Postby Warkton Tornado No.1 » Mon Dec 30, 2024 1:58 pm
As Adam intimates, hot starting can often be an issue, probably never more prevalent than with the PH carburettor many of you patronise.
Unlike the earlier VH, the PH range does not have an in built overflow, so the cold fuel soaks up the heat after the engine has run & there is a tendency to flood, although it only takes a little excess for flooding to occur, probably exasperated by a downdraught inlet. If an air filter is fitted, the problem is exasperated further. Likewise, that other ‘trait’ of having an engine set up too rich - & then some :roll: - will not help matters.
Postby Jeff t » Mon Dec 30, 2024 9:04 pm
Thanks for all the tips all taken with the right intent. I have tried diffent methods but as i dont use it regular as i use my S2 most of the time my normal starting method is no choke or throttle, if i think about it like putting away after use i turn the fuel off for a short time but couldnt say i do that all tne time.
My gut feel after ruling eveything out and all the detail i know that i might have missed explaining, is it goes back to when I fitted the varitronic, had it dynoed but it ran awful and he couldnt set up mid range. So i think its carb related or im really unlucky and its electrical. Plan is to rebuild double check eveything then check elelctrics although not sure where to start but know a man who might know then get it set up on the dyno.
Thanks again for the help.
Jeff t
Postby Jeff t » Mon Dec 01, 2025 11:22 pm
Was browsing the forumn and came across this i posted, thought i would update albeit it was last year when i sorted but I started again and set the carb as per cam lam web site plus a phone call and the air mixture screw was compleletky screwed all the way in reset it and ok now.
Jeff t
Postby Adam_Winstone » Tue Dec 02, 2025 2:17 pm
Thanks for the update. I'm glad that you resolved the issue.
Frustratingly for you, no doubt, this just goes to show that we shouldn't overlook the easy to address, before digging deeper.
Season's greetings.
