Knowledge wrote:Welcome to the forum.
Have you strobed your flywheel in order to see what your timing is doing? If you have marked TDC and 19 degrees (I find 17 degrees a more helpful), then, under the light of the strobe, you should see the pointer on the flywheel on the left of the 17 degree Mark, and moving up to and then to the right of the mark as the revs rise.
If you haven't strobed the flywheel, you could be setting off with a timing setting which will ruin your engine.
Good luck.
