Carbs
Carbs
Postby Bilko » Mon Oct 07, 2024 9:48 am
I’m in the middle of stripping my series 3 to check over seals bearings etc, but the carb sits there. Gets checked and cleaned now and again. We’re often replacing slides, needles, atomisers, jets, etc. but what sort of lifespan (in miles) should we expect from the bodies?
I can’t remember the last time I bought a 30mm Dellorto, which means I’ve been using the same one for a lot of miles. I wouldn’t even like to guess, but many thousands.
Bilko
Re: Carbs
Postby shamrockexpress » Wed Oct 09, 2024 10:50 pm
If its not causing any problems then it aint broke..........so no need to change.
good luck
shamrockexpress
Re: Carbs
Postby ULC Soulagent » Fri Oct 11, 2024 1:38 pm
shamrockexpress wrote:If its not causing any problems then it aint broke..........so no need to change.
good luck
Wise words Damian ;)
