avanti wrote:thanks guys , think retarding is the way to go KTF
Paul_from_Thornbury wrote:I cannot comment for the exact location of your sensor, but I have never understood this fear of anything over 180 deg C. I currently run an MB temp sensor with the sensor under the plug and previously a Trailtech. I run my TS-1 to a temp limit of 230 deg C and have never seized.Used the same limit on an RT195 that used to only get there on fast runs on really hot days. But my TS-1 gets there a lot easier on fast runs. I use the temp limit chart from Rotax for air cooled engines and with an EGT also fitted that works well to the limits on the same chart. I’ve seen the DT advice that says 390/400 deg F (205 deg C) will result in a size but never seen on what basis or where the sensor was placed to measure this.
Adam_Winstone wrote:
keep an eye out for sudden spikes after a refill (amazing variation from one tank to the next)
I think the best way of obtaining consistent, best quality fuel is to avoid Supermarket fuels in the sense of cost saving. Personally, I favour Shell’s premium fuels & tend to seek out the ‘stand alone’ Shell stations.
Despite the high turnover in stations associated with Tesco, Morrisons etc, the fuel related issues experienced with cars has been due to the quality causing pump failure. Supermarkets have their tanks refilled by any of several suppliers whereas BP use dedicated BP tankers, Shell use Shell etc.
Here we go again with supermarket fuel. All e10 unleaded is the same be it shell, esso, texaco, bp, Asda, Tesco etc etc. the only one of those fuels that are genuinely branded is esso. None of the other big names have a refinery in the uk. Gulf doesn’t even exist as an oil company any longer. The local ex texaco refinery to me supplies every petrol station in a 60 mile radius and some further afield. All e10 is made to a British standard so you pay extra for the name not the quality. After advice from the terrible taffs all of my scoots are set to run on basic unleaded as you cannot guarantee getting super unleaded at every petrol station you stop at.
Don’t believe the hype that branded fuel is better quality it’s just more expensive. Take that from someone that made motor fuels for 9 years.
Fast n Furious wrote:The results of that WSCC test were within a few HP of each other (except for the Alchyfuel), which,IMO, is consistant with minor changes in air density that you would expect to see throughout a days worth of testing various fuels in such a manner.
I think this test has little or no merit TBH.
martyn dwane wrote:The same petrol tankers deliver to my local Tesco store and Shell Garage, maybe Shell have a little something added to their petrol, i use both, never noticed any difference in performance or mileage per tank full.
