Quattrini 210
Quattrini 210
Postby tommy200184 » Sat Aug 31, 2024 9:45 am
Hello everybody,
I'm going to build a Quattrini 210 engine. I've got the pm fat mamba exhaust. I'm wondering what would be the best gear box set up. I think I will use a 5 speed gear box from AF. Wich one should I buy? The Close Ratio 34 teeth or the Close Ratio 35 teeth? And wich sprockets to use? 17x46 ?
Sorry for my english, I'm french.
tommy200184
Re: Quattrini 210
Postby Fast n Furious » Sat Aug 31, 2024 10:41 pm
With this engine I'd be looking for a good spread of power from 7k -8.5k with the Mamba. So, a 19/34 on the 5th with a 17/46 on the primary should work out ok but it depends on other factors as well including how you want it to ride. If you find this setup to be slightly undergeared, then a simple, easy and cheap upgrade to a 18T front sprocket may be all that is needed.
Re: Quattrini 210
Postby tommy200184 » Sun Sep 01, 2024 1:46 pm
Ok, thank you for your answer
tommy200184
Re: Quattrini 210
Postby Knowledge » Tue Sep 03, 2024 11:36 am
If you choose the wrong fifth gear, don't worry, you can still buy the alternative fifth gear from AF, as a I did. :roll:
Your English is good.
Re: Quattrini 210
Postby Toddy » Wed Sep 04, 2024 8:55 pm
Does the pm pipe fit the quattrini ?
Re: Quattrini 210
Postby missing lynx » Fri Sep 06, 2024 4:19 pm
Is your fat mamba pipe specifically for the Quattrini? As if not will need quite a bit of work to fit
Re: Quattrini 210
Postby tommy200184 » Sat Sep 07, 2024 9:35 am
Is the Af close ratio a good choice, or the casa cyclone 5 would be better?
tommy200184
Re: Quattrini 210
Postby ULC Soulagent » Tue Sep 10, 2024 12:18 pm
tommy200184 wrote:Is the Af close ratio a good choice, or the casa cyclone 5 would be better?
How deep are ur pockets?
As previously posted is the pm pipe actually made for the Quatt?
Re: Quattrini 210
Postby tommy200184 » Tue Sep 10, 2024 4:37 pm
Yes the pm pipe is actually made for the Quattrini.
tommy200184
