Warkton Tornado No.1 wrote:….What would be great now is if somebody with experience of a LH manifold could chip in & say how they have got on with their TS or RB fitted with such…..
Storkfoot wrote:Warkton Tornado No.1 wrote:….What would be great now is if somebody with experience of a LH manifold could chip in & say how they have got on with their TS or RB fitted with such…..
I have a 225 TS1 with PHBH30. For years, I ran it with a RamAir filter through a hole in the panel of my GP. I used an MB inlet manifold with 3mm packer. It ran well. It was a 19/20 bhp TS1, not the fastest around by any means but, with a CST3, it was nice and smooth to ride with no noticeable flat spots.
Eventually, I got fed up of staring at rev counters, an expansion pipe and a filter sticking through the panel. I wanted a scooter that looked like a scooter, if you know what I mean.
I bought an LTH linkenummer inlet manifold to fit on the near side and to allow me to allow the carb to breath under the panels. I bought a RamAir sock type filter to fit on the intake elbow below.
https://www.scooter-center.com/en/air-i ... mm-2211016
Since then I have added a drain hole to this rubber as there was petrol pooling at the bottom of the intake. The intake just, only just, touches my GP panel but it isn’t compressed.
As I changed the exhaust to a Ron Moss Avanti around the same time, and as I have not had it on a dyno in recent years, I can’t give you a scientific analysis of how performance has been affected. My personal conclusions, from my messing around, is that:
The LTH Linke Nummer made no difference to performance. Sadly, LTH have ceased trading now though.
The Ron Moss Avanti, compared to the CST3, produces a very small reduction in top end power (remember the CST3 is not a top end power pipe anyway, it is good from around 3500 to 5500 revs, from memory). But, I have not felt the need to change the jetting with the Ron Moss Avanti so both exhausts must have similar characteristics.
I would say, however, that the Air Intake has taken the edge off performance. In my case, I am not too unhappy with this.
Most of this is irrelevant to the OP. To the OP, I’d say that the LTH Linke Nummer works well on my TS1. There is plenty of clearance to the frame and, if you wanted to run open under the panels, it is not so close to the panel as to strangle performance badly.
Storkfoot wrote:This is the drain tube. It only has a small hole and, personally, I doubt it makes a perceptible difference to jetting.
https://www.lambrettaspares.com/mbp0692.html
Storkfoot wrote:I have tried making my own sock filters with the foam you can get off eBay and a glue gun. Messy and hard to not end up with something that looks like my granddaughter made at pre school.
Warkton Tornado No.1 wrote:When I tried the pre-oiled type of filtration, I felt that the engine was stifled, though I cannot quote the foam filtration figure now. I just wonder whether anybody has any comment on the subject of non-oiled versus pre-oiled, particularly when fitted to a powerful engine gulping large quantities of air
johnnyjarvis wrote:Thanks for the replies . I have thought fitting a manifold that puts your carb on the flywheel side.
A mate has done this and runs a phbh. I don’t think the longer vhsh would fit.
Storkfoot wrote:My personal conclusions, from my messing around, is that:
Warkton Tornado No.1 wrote: Are you sure? I just checked Eurocarb & overall length is 86.5 mm whereas the PHBH is 90.5 mm. You should check their site yourself as I may have misread it
