Chiselspeed m-tech timing adjuster
Postby a-teamlambretta » Thu Mar 14, 2024 8:00 pm
Just building up a motor and have an m-tech box ...no instructions. Anyway I presume the 2 red wires from the box go between the the red pic up from the stator and CDI, one is black wire from the box is an earth . What's the other wire for ....looks like another earth?
Cheers Simon
a-teamlambretta
Re: Chiselspeed m-tech timing adjuster
Postby gizmo » Thu Mar 14, 2024 9:47 pm
There used to be a wiring and set up pdf on mb tech site. Presume it's still there
gizmo
Postby a-teamlambretta » Thu Mar 14, 2024 10:02 pm
Yes there is....but it only shows a box with 2 red and one earth ...just had look on mb site .
a-teamlambretta
Postby Rich Oswald » Fri Mar 15, 2024 9:52 am
a-teamlambretta wrote:Just building up a motor and have an m-tech box ...no instructions. Anyway I presume the 2 red wires from the box go between the the red pic up from the stator and CDI, one is black wire from the box is an earth . What's the other wire for ....looks like another earth?
Cheers Simon
Simon, i've probably got a set of Chiselspeed's instructions in the garage, I will have a look for you.
Postby a-teamlambretta » Fri Mar 15, 2024 4:22 pm
Cheers Simon
Afternoon Rich,
That would be great.
Cheers Simon.
a-teamlambretta
Postby Toddy » Fri Mar 15, 2024 8:10 pm
There you go Mr Walker
Postby a-teamlambretta » Fri Mar 15, 2024 9:33 pm
Toddy wrote:There you go Mr Walker
That's the one....
Cheers Mr T.
a-teamlambretta
