Taffspeed stainless steel u- pipe
Postby johnnyjarvis » Sun Feb 18, 2024 1:09 pm
I seen these someone had made these recently.
Anyone know who had made them ?
Cheers, Will
johnnyjarvis
Re: Taffspeed stainless steel u- pipe
Postby gaz_powell » Sun Feb 18, 2024 1:31 pm
I would have one them!
Postby ste s one » Mon Apr 15, 2024 10:55 am
Just wanted to resurrect this thread in case anyone had an update ion the Taffspeed headers ?
ste s one
Postby gaz_powell » Mon Apr 15, 2024 1:52 pm
As soon as i have time i intend to see how close the SSC taffy pipe u bend is to the original.
Ive got a gen taffspeed and a few SSC ones.
Postby ste s one » Mon Apr 15, 2024 2:54 pm
Hi Gaz ,
I have an SSC copy lying around somewhere , and from memory they are significantly different . I know that the fitting into the stub is quite a bit smaller diameter for a start .
ste s one
Postby Dazts1 » Tue Apr 16, 2024 8:38 pm
The taff u pipe fits over the expansion body where the Saigon copy slips inside the expansion body. Plus as you said the Saigon version is probably close to 42mm ( the version I’ve seen is ) where the taff is probably closer to 48mm.
Postby Dazts1 » Tue Apr 16, 2024 8:39 pm
If someone is knocking the u pipes up I’d be intrested.
Postby gaz_powell » Tue Apr 16, 2024 9:09 pm
Early SSC were 42mm but they went to 48mm. Thwy have had a few changes.
Yes knew the joints were different just wondered if the bend was in the ball park.
Ive also got a 48mm u bend (unknown) that is just the tube with no ends, think it could be just a 48mm AF clubman, will see if thats anywhere near..... When i have some time!
Postby Ralph95 » Wed Oct 23, 2024 8:25 am
I am planning to make batch in the near future for the mk4 Taffspeed
Ralph95
Postby gaz_powell » Thu Oct 24, 2024 6:29 pm
Im not sure what mk mine is.
The bends not bad, but would like a new one.
Keep us updated
Postby Dazts1 » Sun Oct 27, 2024 11:38 pm
I’ll definitely have one. If it’s the larger circliped end can Gaz that’s the mk4 Goldline ( with separate u pipe) . The earlier riveted can (As JL were ) pipe didn’t have a separate u pipe. The chamber and u pipe were all one.
Postby gaz_powell » Mon Oct 28, 2024 4:57 pm
Cheers Daz... Ive got a Mk 4!!
Postby Toot » Tue Oct 29, 2024 4:46 pm
Ralph95 wrote:I am planning to make batch in the near future for the mk4 Taffspeed
Hi Ralph
Put me down for 3 of these please. I assume they will be steel, not stainless?
What timeline are you working to for the production of these downpipes please?
Simon
Toot
Postby Ralph95 » Thu Oct 31, 2024 10:07 am
Hi Ralph
Simon
There going to be stainless steel msg me for more details
Ralph95
Postby Toot » Mon Nov 04, 2024 7:35 pm
Ralph95 wrote:
Hi Ralph
Simon
Sent you a msg on here Ralph.
Toot
Postby Ralph95 » Tue Nov 05, 2024 8:26 pm
Hi all I am waiting for the Main bends to turn up they have been delayed due to a production issue as soon I as get them I'll be on with them :D
Ralph95
Postby Ralph95 » Fri Nov 29, 2024 3:41 pm
Hi everyone the first prototype U bend has been welded doing some final checks then hopefully I'll make a batch, I have some idea of cost but holding back on that for a minute
Ralph95
Postby Dazts1 » Wed Jan 01, 2025 8:31 pm
Sounds good keep us updated as I’m sure you will.
Postby gaz_powell » Fri Jan 03, 2025 7:12 pm
Eagerly awaited...
Postby Toot » Fri Jan 10, 2025 8:12 pm
Ralph95 wrote:Hi everyone the first prototype U bend has been welded doing some final checks then hopefully I'll make a batch, I have some idea of cost but holding back on that for a minute
Any further update Ralph?
Toot
Users browsing this forum: Baidu [Spider] and 16 guests
