TS1 200cc piston alternative 66mm
Postby al pushpak » Thu Jan 11, 2024 10:28 am
Hi all, is there an alternative piston available besides the ASSO type that can be run in a TS1 200, my set up is going to be run with an RD 200/RG 500 style conrod kit from Chiselspeed used with either a 2.5mm or 3mm cylinder packer, so was just wondering about the different piston crown heights? thanks
al pushpak
Re: TS1 200cc piston alternative 66mm
Postby martyn dwane » Thu Jan 11, 2024 12:37 pm
I run a wiseco piston in my TS1 200 but run with a RD400 conrod.
martyn dwane
Postby al pushpak » Thu Jan 11, 2024 1:08 pm
martyn dwane wrote:I run a wiseco piston in my TS1 200 but run with a RD400 conrod.
ok, thanks for that
al pushpak
Postby gaz_powell » Thu Jan 11, 2024 9:54 pm
I'm running an RD400 rod with Wossner IT 175 piston.
Had 1mm off bottom off barrel to get correct sqush.
Head is SIL machined as piston crown profile different to a lambretta piston
Postby Knowledge » Fri Jan 12, 2024 8:31 am
Mitaka do a 66mm piston for the RD350 and 350YPVS on the last oversize. Have a look at the website.
https://www.mitaka.co.uk/ROAD_BIKE_PISTONS/YAMAHA/350LCP
Just saying.
Postby hullygully » Fri Jan 12, 2024 12:17 pm
gaz_powell wrote:I'm running an RD400 rod with Wossner IT 175 piston.
+1 plus a Broady re-profiled head 8-)
or even use a Yamaha IT175 piston if you can get one
Postby Fast n Furious » Fri Jan 12, 2024 8:02 pm
Knowledge wrote:Mitaka do a 66mm piston for the RD350 and 350YPVS on the last oversize. Have a look at the website.
Just saying.
I use this 36mm comp height piston with a 110mm conrod setup on my TS1/200. It does mean having to repeg the postion of one of the rings though.
