RT195 with original Taffy expansion- gearing recommendations
Postby Bidsy » Wed Nov 08, 2023 11:38 pm
I’m after bit of advice from you guys if possible please. I’m building a small block RT195 ( piston ported) and have an original Taffy expansion to go with it plus Italian LI150 gearbox and 46 crown wheel. Could anyone recommend what final gear ratio I should be aiming at for a good touring setup (13 stone and a bit of luggage ) I want to be able to sit comfortably on a motorway at 60mph but still have a bit left in the tank of overtaking. Also recommendations of carb size. Thanks
Bidsy
Re: RT195 with original Taffy expansion- gearing recommendat
Postby Rich Oswald » Thu Nov 09, 2023 12:03 pm
I have a Taffy Mk 4 on my Muggy 225. I had an Italian GP200 box on at first, so same FDR ratio as LI150 (5.2) but went to 19/46 (4.8) FDR which I stayed at when I went 5 speed. Pulled great for me but i'm only 11 stone. Defo go at least 16/46 but may pull 17/46 which is what I have on my RT225 reed (5speed). May be trial and error.
Postby Bidsy » Thu Nov 09, 2023 11:58 pm
Does the Original Taffy produce its power high up or low low the power range?
Bidsy
Postby GP Kevo » Fri Nov 10, 2023 2:51 am
If it's their road pipe then the power is pretty low down with the peak power at around 7,000 RPM. The road exhaust is in two parts not including the silencer. The down pipe connects to the exhaust flange. Then that connects to the main expansion pipe with two springs
If it's like a JL4, really fat, one piece and with a really long stinger leading back to the silencer, then it's their race pipe. That exhaust makes power much higher up in the revs.
Hope that helps.
GP Kevo
Postby Rich Oswald » Fri Nov 10, 2023 12:03 pm
Bidsy wrote:Does the Original Taffy produce its power high up or low low the power range?
Low down the power range. It's a touring pipe with plenty of torque.
Postby Bidsy » Fri Nov 10, 2023 6:44 pm
Look like I have the road version, So am I right to assume it delivers power similar to that of a box pipe and would be better suited to a FDR of around 4.9 rather than 5.2?
Bidsy
Postby Rich Oswald » Fri Nov 10, 2023 11:06 pm
Bidsy wrote:Look like I have the road version, So am I right to assume it delivers power similar to that of a box pipe and would be better suited to a FDR of around 4.9 rather than 5.2?
IMO yes.
Postby ULC Soulagent » Wed Nov 15, 2023 1:14 am
Me personally I’d settle for 5.2 fd with the expansion pipe ;)
Everyone is different though so case of suck it n see
30 phbh delly as well
Postby hullygully » Wed Nov 15, 2023 11:59 am
I had Taffy exhaust for years, got bored with hitting the invisible wall, then changed to a Franny tourer :P , then upped to a super tourer 8-)
