TS1 with left hand inlet manifold
Posted:
Mon Nov 06, 2023 9:47 pm
by a-teamlambretta
Anyone using a left hand inlet manifold on a TS1 cylinder?. I don't want to hack the battery tray off my series 1. Is there enough clearance ect ?.
Cheers Simon.
Re: TS1 with left hand inlet manifold
Posted:
Tue Nov 07, 2023 8:22 am
by Knowledge
Sticky has one on his TS1 240 and Superhooper on here has one too on his pretty standard TS1 225.
Both engines are good.
Posted:
Tue Nov 07, 2023 8:48 am
by Storkfoot
Posted:
Tue Nov 07, 2023 2:09 pm
by jonoy
I have a LTH left side manifold on my TS 1 on my GP
All good
Posted:
Tue Nov 07, 2023 6:34 pm
by superhooper
Used offset cones to give more clearance. All good
Regards Super
Posted:
Tue Nov 07, 2023 8:33 pm
by Norrie Bodge
jonoy wrote:I have a LTH left side manifold on my TS 1 on my GP
All good
+1
Using a skimmed reed block (by half) & 3mm reed packer
no issues
Posted:
Tue Nov 07, 2023 9:37 pm
by a-teamlambretta
Thanks to all for the info... will get one ordered.
Cheers Simon.
Posted:
Wed Nov 08, 2023 9:29 am
by Leotech
Again see other TS1 exhaust post, I also asked Ben about a left hand manifold as my bike is UK from new with a battery tray which I don't wish to hack off, He said same as he did about the box pipes and PHBH carbs.
With a PHBH and an Avanti type box pipe the left hand manifold is not noticeable, But if you go for full on flat slide and a high revving expansion pipe etc, you will notice a drop in performance.
Posted:
Thu Nov 09, 2023 12:15 am
by a-teamlambretta
Posted:
Mon Nov 13, 2023 10:32 am
by Leotech
I should have said AF Ben has them in stock.
Posted:
Wed Jan 03, 2024 10:25 am
by al pushpak
will one of these fit a Monza 225? cheers
Posted:
Wed Jan 03, 2024 1:57 pm
by a-teamlambretta
al pushpak wrote:will one of these fit a Monza 225? cheers
Yes ...I was using an imola manifold on the ts1 prior to going left hand manifold.
Cheers Simon
Posted:
Wed Jan 03, 2024 2:03 pm
by al pushpak
cheers
