Exhaust fit question
Postby jdevane5 » Sat Jun 10, 2023 4:01 pm
I have just built an RT230 engine and have got myself a JL3 exhaust.
Is there any issue if I fit the exhaust onto the engine ahead of engine fit into frame (its a 1990 SIL GP150 frame)
Last question the spring on the JL3 exhaust, manifold end , does that go fly wheel side?
Cheer
JD
jdevane5
Re: Exhaust fit question
Postby hullygully » Mon Jun 12, 2023 9:00 am
try to make sure the stub sits neat inbetween the fins
check gasket to port, trim / file to suit
check stub to gasket, file / grind to suit.
try and fit 2 springs from stub to exhaust body, its an area you don't notice till exhaust blows or drops off :o
Users browsing this forum: Baidu [Spider] and 48 guests
