CasaCooler / SIP Vape
Posted:
Fri Jun 09, 2023 11:42 am
by Solid Air
Anyone using the conbination of CasaCooler and SIP Vape? I'm interested in how close the supplied fan sits to the Casa flywheel cover.
Thanks, Mark
Re: CasaCooler / SIP Vape
Posted:
Mon Jun 12, 2023 10:24 am
by bike grim
Think Rob Gray has done so
Posted:
Fri Jun 16, 2023 9:13 pm
by dscscotty
Hi Mark, I've fitted several, they run close, good for flow, be aware that depending on which cooler it is the fan does at times require the fins machining on an angle to fit correctly
Regards
Scotty DSC
Posted:
Fri Jun 16, 2023 9:41 pm
by Solid Air
Thank you Scotty, that's great info!
Posted:
Fri Jun 16, 2023 9:51 pm
by Solid Air
bike grim wrote:Think Rob Gray has done so
Thanks Gareth
