GT186 kit vibration
Hi, I have just been out for the first run on my rebuilt Series 2 and it isn't running quite as expected/hoped. At lows revs there is a lot of vibration. I dont have a rev counter but I would guess anything below say 3000-4000 rpm is quite unpleasant to ride at. Above that rpm it is quite smooth and pulls well. The vibration is enough for the top of the legshields to be vibrating back and forth about 15mm.
On the basis it goes quite well at the top end I was guessing carburation, that said if I close the throttle going down hill it still vibrates.
Any thoughts on where I should start, or would I be better taking it to a dyno to get it right ?
The spec is
- GT186 kit with GT head, squish is 1.3mm
- New GT 60/110 crank
- New Mains (FAG)
- New Mid weight flywheel SIL based (I think)
- New Read speed magneto
- 19/47 gearing
- GT tensioner
- Li150 gearbox
- New chain, layshaft, output bearing ....
- Casa Remote air filter
- Avanti Clubman
- 25mm Dellorto jetted as per GT instructions
- Needle D22
- Slide 40
- Needle Jet AQ266
- Pilot 55
- Choke 60
- Main 102 (upped from 97 because of remote filter)
When I built it I did a leakdown check and it was all fine.
The spec is
- New Mains (FAG)
- 19/47 gearing
- GT tensioner
- Li150 gearbox
- Avanti Clubman
- Needle D22
- Slide 40
- Needle Jet AQ266
- Pilot 55
- Choke 60
