casatronic no spark
casatronic no spark
Postby lofty » Mon Feb 13, 2023 11:24 am
Hi all..
after a short lay-up i cant get the bike started, after checking fuel i checked spark (nothing either visually, or by using finger/shock test)
here is what I have eliminated so far.. plug, cap, ht lead, ign switch and wiring, wiring from stator, stator continuity/resistance, earths, the connections to regulator and cdi look sound..
It was running last time it was used, so I am doubtful but maybe something has failed?
has anyone any experience of similar issues they may have had?
also, as a matter of interest, what triggers the spark in the flywheel? I can see what appears to be 4 magnets inside, but nothing that looks like a trigerry thing??
lofty
Re: casatronic no spark
Postby Toddy » Mon Feb 13, 2023 5:48 pm
lofty wrote:Hi all..
It’s not something daft like an ignition switch earthing out ?
Postby lofty » Tue Feb 14, 2023 10:50 am
unfortunately not :(
I am resigned to trying alternative CDI/regulator, but I dont have spares so need to open the wallet :cry:
I would have hoped with a 'modern' all singing and dancing and expensive setup life would be easier, but alas.......
lofty
Postby bike grim » Tue Feb 14, 2023 2:11 pm
Which casatronic ? The new style or the older IDM 4 pole like the Varitronic ? If it’s the older type the spares for those are cheaper on German eBay - you can get coil pack that bolt to the back plate and also CDI units. Last time I looked were cheaper than cam lam
Postby lofty » Tue Feb 14, 2023 3:00 pm
its the new 12 pole advance/retard version
lofty
Postby Adam_Winstone » Wed Feb 15, 2023 11:47 pm
Strangely, when I first built mine I could not see or feel a spark from plug or HT but was told to try it with the plug a d lead fitted to the motor... and it fired up normally! Perhaps there is a little 'voodoo' with the new system?!
I believe that one of the earth points is very important too.
Good luck.
Postby lofty » Thu Feb 16, 2023 5:24 pm
Thanks Adam,
voodoo eh, it kind of makes sense, i may have to find a goat to sacrifice.. I will post back my findings :lol:
lofty
Postby lofty » Fri Feb 17, 2023 5:59 pm
yep it was voodoo..
not so much as a spark or a tingle from the HT, but put it all back together and kicked it over.. burst into life 3rd kick..
and goat curry for tea...
lofty
Postby Toddy » Fri Feb 17, 2023 6:00 pm
lofty wrote:yep it was voodoo..
Happy days not sure about the goat curry though :lol:
Postby Adam_Winstone » Fri Feb 17, 2023 9:37 pm
Brilliant!
Thanks for the update. It's really good to hear that comments have helped others.
Result!
