Varitronic type ignitions
Posted:
Sat Dec 17, 2022 10:15 pm
by gp200ts1
Has anyone converted a varitronic type ignition to full dc? I have a scooter which is fitted with a scootopia varitronic type ignition and the lights at lows revs are abysmal so I would prefer full dc.
Re: Varitronic type ignitions
Posted:
Mon Dec 19, 2022 9:46 am
by jonw
Varitronic diagram here shows the regulator has optional battery output...
viewtopic.php?f=10&t=5440
Posted:
Mon Dec 19, 2022 6:43 pm
by gp200ts1
Yes but that is dc enough to trickle charge a battery. I want a full dc system.
Captain pug wash has steered my in the right direction to an old posting of his showing how to convert the stator.
Posted:
Tue Dec 20, 2022 6:42 pm
by Adam_Winstone
Captain Pugwash is a star with electrics
Posted:
Tue Dec 20, 2022 6:43 pm
by Adam_Winstone
... and most things Lambretta.
Posted:
Wed Dec 21, 2022 9:00 am
by coaster
Just be aware that converting the stator to DC alone will not make any difference to your lighting. If you fit a battery though it will supplement the low stator output at low revs so that your lights are at full power. BUT, when the battery runs down when a lot of slow riding is involved then your lights will only have the stator output to rely on and will be the same as with an AC system. Personally I'm happy to put up with this and top the battery up with a mains charger every few weeks.
The Captain is indeed a genius
Posted:
Wed Dec 21, 2022 2:53 pm
by Binny
Don't know if this is of any interest to the op but I run a Varitronic system with DC and AC lights.
I use a gel type burglar alarm battery which just fits on the standard battery tray and which gets trickled charged during normal riding.
All I've done is wire the main lighting feed up so that I can switch (hidden in the standard air scoop under the seat) between battery DC and AC supply.
If I'm riding during the day and want the lights on constantly because it's crap weather then I have it on AC. If I'm riding at night and at low speeds then I switch to battery DC so the lights are bright regardless of engine speed.
Obviously if I use it on DC for more than an hour or so then the battery draw will start to outstrip the trickle charge and I would have to switch back to AC.
Posted:
Fri Dec 30, 2022 9:11 pm
by Wack
Captain Pugwash and myself worked together a few years back to change the Varitronic to DC.Something I've now done to several scooters including one yesterday but with a far easier way of doing it without removing the resin on the terminals.I will say that you will have great lights but it's best to run LED's and avoid high wattage front halogens especially if running instruments or a SIP speedo as the voltage drops from 14.5 to between 12 to 13v with everything on.One of the reasons I converted to HID a few years back as low wattage but BA20D's are now available in LED although I haven't tried one yet.
Posted:
Mon Apr 24, 2023 4:39 pm
by Soulsurfer
Wack wrote:Captain Pugwash and myself worked together a few years back to change the Varitronic to DC.Something I've now done to several scooters including one yesterday but with a far easier way of doing it without removing the resin on the terminals.I will say that you will have great lights but it's best to run LED's and avoid high wattage front halogens especially if running instruments or a SIP speedo as the voltage drops from 14.5 to between 12 to 13v with everything on.One of the reasons I converted to HID a few years back as low wattage but BA20D's are now available in LED although I haven't tried one yet.
Resurrecting this thread as I’m interested in this… Pm sent Wack.
