Iron barrel or nicasil lined ali barrel?
Postby Knowledge » Mon Jun 02, 2014 10:48 pm
Which is best? Why?
Discuss
(BOK)
Re: Iron barrel or nicasil lined ali barrel?
Postby Tony Hart » Tue Jun 03, 2014 6:52 am
It has got to be iron - because that is what is on mine :D . If the technical answer is actually a nicasil lined one then I will end up talking myself in to buying one :oops:
Tony
Tony Hart
Postby Knowledge » Tue Jun 03, 2014 7:24 am
I'm not sure there is a right answer to this, but I thought it might be useful to Lambretta owners to see a few opinions before they make a decision. After all, the GT kits prove that not all after markets need to be invasion lined Ali barrels
Postby HxPaul » Tue Jun 03, 2014 9:06 am
I always thought that a nicasil lined ali barrel was better for cooling because the piston and barrel expand at the same rate.
Postby Knowledge » Tue Jun 03, 2014 3:40 pm
Very true Paul, but then if you damage an iron barrel, you can rebore it, which is cheaper than re-nicasilling the ali barrel.
There are pros and cons.
Keep 'em coming
Postby Paulnobodyimportant » Tue Jun 03, 2014 4:47 pm
I really fancy the new GT kit, which is cast iron, which I would fit to a TV200 engine that I would obviously need to upgrade, but with the TV200 gearing. The advantage of this cast iron kit is the out of the box performance, see current scootering issue, plus I can have the carb on the LH side, so as to avoid taking the original battery tray of a TV200 scooter. But the major disadvantage is that I would probably need to do a 1000 miles of running in, (See Edens post about having to run his in). The trouble is that for the last 2 years, i don't seem to have time to do a lot of long runs, so it would take me a long time and would be frustrating, to now run a cast iron barrel in. The other advantage is the numerous re-bores that you can have. But for the amount of miles i do and the potential time I've got left on the conveyor belt of life, this is not a consideration. Disadvantage is perhaps cooling if you have an engine running at very high revs,
With the niscali/ali barrel and i've got three such kits, after 200 or 300 miles, i took it as run in, then ran at full wack, where allowed and never had any issues. In fact on my malossi kit, it said run the engine for one hour, at various revs and off you go, which i did. So for me the advantage is lower running in periods and less fear of heat seizures due to the better cooling.
To keep standard carb side, I suppose I could go with a mugello, but they don't seem to have the same out of the box as the above GT kit; or do they.
So far, which kits are vexing you?
Paulnobodyimportant
Postby HxPaul » Tue Jun 03, 2014 5:05 pm
I thought that the GT kits were only made for small block engines.
Postby joespeed » Tue Jun 03, 2014 5:49 pm
alloy barrel steel liner,this will allow for an odd mishap(seize) due to heat ,alloy with plate is the modern way to go but as fuel is crap and the lack of original heat sensors on the scooters having said that the only one i have worn out is a big 250 rapido,
alloy plated and fit a heat sensor,plus the setting up on the dyno and fit a hand operated choke on the handle bars!
joespeed
Postby jonashford » Tue Jun 03, 2014 6:11 pm
I have an Ally rb barrel sleeved with steel or iron im not too sure, AFS did it thru PJ lining I think theyre called. Anyway it works for me, the running in was a pain but in the long term I feel the benefits are better, wears faster but if it goes bang Ill not be off the road for very long. Which is better for me.
jonashford
Postby Paulnobodyimportant » Tue Jun 03, 2014 9:51 pm
HxPaul wrote:I thought that the GT kits were only made for small block engines.
Keep up HxPaul
Have a look at the link below + current issue of "Scootering."
http://www.scooterotica.co/forum/viewto ... 7&p=220196" onclick="window.open(this.href);return false;
Paulnobodyimportant
Postby HxPaul » Wed Jun 04, 2014 9:57 am
Keep up HxPaul
http://www.scooterotica.co/forum/viewto ... 7&p=220196" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Wow,that looks awsome.I have a small block engine with a Casa 185 kit at the moment,but I also have a GP 200 engine case and I could be tempted with the GT 200 kit.
Postby dscscotty » Fri Jun 06, 2014 7:04 am
Having ran and tuned steel lined alloy barrels for almost 20 years I am on the side of liners/re-boreable bores as preference to nicasil. Whilst I appreciate the pro's of nicasil I have all to often seen the effects of damaged cylinders at the road side,which I'm afraid often means a journey in a recovery van. It's not a pretty sight watching the owners of nicasil lined barrels inspecting the damage after issues such as seizures as they see a piece of plating is missing from the cylinder wall. Where as iron/steel lined cylinder seem to be a little more forgiving and can often be cleaned up enough to get you going again. I know of a group 6 RB250 that runs a steel lined RB cylinder and the rider agree's that the lined cylinder offers a good advantage in that he has noticed a higher running temp on the lined barrel does not always lead to siezure as he's lined barrel has exceeded tempratures that had often led to issues on his previous nicasil lined barrel. My own theory on that is that the liner is more pliable and thus able to allow for greater piston expansion. For me lined/iron ally barrels are the best of both worlds and offer some considerable advantages over nicasil/chrome bores.
Remember the old saying "Chrome don't get you home"?
Scotty-DSC
Taken from Mitaka site (Grampians):
Plated Cylinders
Pros
Cheaper to manufacture (initially)
Lighter by about 150gm (125cc cylinder).
The plated surface is very hard and suffers almost no wear.
However the aluminium behind it is soft and “packs back” over time, resulting in an increased piston clearance, even without bore wear. This cannot properly be rectified with a larger grade of piston since the wear is not uniform and a larger grade piston will be at risk of seizure.
Can potentially run very small piston to bore clearance to give a performance advantage.
Very few engine builders, or indeed manufacturers are prepared to run so close to the edge for their customers. Almost all choose to run clearances in the order of 0.040mm, exactly the same as a linered cylinder! – Forged pistons often need even larger clearances!!
Cons
Expensive and very time consuming to re-condition – cannot be rebored.
Cannot easily be honed to remove small imperfections or damage so that even the smallest fault cannot safely be rectified.
Running an imperfect cylinder risks plating detachment and total failure with potential catastrophic collateral damage to the rest of the engine.
Linered cylinders.
Pros
Mitaka offer an economical relining service.
The initial wear can be easily corrected by honing and a larger grade piston fitted to restore the exact specification.
Extended wear or serious damage can be economically repaired by reboring.
Cons
Heavier (150gm)
Can’t think of anything else, unless you can afford a new cylinder for every race.
WHICH IS THE BEST SOLUTION FOR YOU ?
Postby amb » Sat Jun 07, 2014 8:37 pm
Been thinking of putting steel liner in my ts1 225 for some time , decided to bite the bullet and go for it . would appreciate any help /thoughts ie is piston to bore the same as nicasil lined ?, pjme say no issues with heat it runs the same temp Mmm not sure about that ,not a balls out rider like to cruise at 65/70 with cht on trailtech set at 170 for danger but dont usualy get up to this , shame all the previous posts on site have gone but hey ho we will get there ,Believe Eden is the man for steel liners . Oh yea what about running them in ,might be basic stuff for some people but we need this info building up again , Thanks in advance .
amb
Postby amb » Sat Jun 07, 2014 10:21 pm
Thanks for that Eden , Well i will give it a go and see how i go on .Any info i gather will be put on the forum good or bad but could be a while yet .
amb
Postby dscscotty » Sun Jun 08, 2014 6:42 am
With regards to lined TS barrels and road use, I can assure you they offer more advantages than cons. Cooling is more efficient than a full iron barrel, prolonged high speeds can be held without the problems sometimes incured by iron barrels. They can be re-bored should wear or damage occur. There is also now more Ts1 style or similar pistons available in size increments that are suitable for Lambretta type set-ups i:e 107x 22x16 rods so they make it relatively easy to re-bore. There has been occasionally suspicion around the hardness and suitability of some liners, however this can at times down to other issues that have led to problems relating to bore wear or similar propblems. A clubmate of mine runs a lined TS1 of which I check the bore anually and at last check at the start of the year it was still running just a tad over 4" clearance. This is after nearly 4 years hard rallying which included one solo LCGB championship winning year and more recently the LCGB LE-JOG. The only service work undertaken is an occasional degalze of the cylinder and new rings which are fitted at the start of the rally season. The owner of this scooter was very sceptical when I replaced the damaged nicasil surface with a liner but now fully appreciates the advantages and has no concerns and infact prefers them.
Scotty
Postby dscscotty » Mon Jun 09, 2014 5:50 pm
Hi Eden pm sent:
Postby Bristol Daz » Tue Jun 10, 2014 8:18 pm
It's a bit late for the Swiss adventure, but I'm seriously considering having my Monza lined, could you give me an idea of time & cost Scotty. Maybe we can get together and have a chat during the euro?
Bristol Daz
Postby dscscotty » Wed Jun 11, 2014 8:23 am
Hi Daz
Not going to Euro, however you can give us a call or pop through and I'll get the kettle on.
Postby Bristol Daz » Wed Jun 11, 2014 6:04 pm
Thanks Scotty I'll give you a call when I get back and we can discuss options
Bristol Daz
Postby speedy » Thu Jun 12, 2014 8:57 pm
I personally have been running TS1's since 1987, always with nicasil and love them. I've never had a linered cylinder as nobody has ever done me one, and that's probably the only reason. I am going to be building my Italian gp 150 0ver the coming winter with a large block motor. Now firstly I was going to do a TS1 again, but no matter how much I thought about and the possibility of different specialised set ups, it seemed silly having two bikes with the same kit at the end of the day. I thought of possibly having a piston port job, say Rapido or Mugello, but as I am also finishing off a stage 4 jet 200 ,decided against this. The Avanti seemed another option until I began following the saga of the GT 200 Big block. I have now chosen to get one at the end of the year and have a cast barrel as a second rally bike. I hope I am choosing wisely on what I've seen and read. Only time will tell. Another question is, regards Ali barrels, how do folk rate Ceramic plated Ali barrels?cheers,Speedy. :D
speedy
Users browsing this forum: Bing [Bot] and 58 guests
