hullygully wrote:I built one up for a mate about 8yrs ago, using an Indian GP200 box, 20T x 47T
5 x plate Fox Hat clutch
110 Jap rod GP crank
17 deg static timing on a 70mm Bore
3mm barrel spacer
Franny exhaust? & 30mm Delly (no jetting available)
Adam_Winstone wrote:I have run with various pipes and ignition combos.
Euro Avignon - JL3 and static ignition, being a reliable tourer and doing Avignon to Orleans in a day, without issue. However, whilst 'fine', I found the power delivery sedate, with the JL3 limiting the ability to scream it if wanting to.
Euro Germany - Fran Supertourer and Agusto 6k advance/retard ignition. NB: When I first tried the Supertourer with the same static that the JL3 had run with, I was shocked at how much lower down power I had lost. Indeed, so much bottom end lost that I had to try other setup ideas! That said, the rev-on was dramatically extended so I decided to persevere... and fitting the advance/retard worked wonders; all of the bottom end back and keeping the over-rev, for no change of gearing (4.8:1).
Out of these configurations the Supertourer is easily my favourite, for the odd hooligan blast and/or reliable touring. In your shoes I would think that both of your pipe options would benefit from advance/retard.
shamrockexpress wrote:hullygully wrote:I built one up for a mate about 8yrs ago, using an Indian GP200 box, 20T x 47T
3mm barrel spacer
So what was the power delivery like?
Jeff t wrote:Just reading this back I went for the 4 speed Casas great bit of kit maybe be a bit expensive but I would certainly recommend it.
