Gt186 / cyclone 5 /FDR?
Postby swissdean » Tue Sep 20, 2022 4:48 am
Morning, trekking it from Switzerland to Woolacombe and struggling to pull top gear on my cyclone 5(v2). Curios what others are running . My set up is gt186 ( out of the box), 110/60 crank, 30 mm phbh, 18 degs static, casa perf filter, 4.71 fdr with 46/19 cogs and bgm v4 sport ( curly one)
Pulls lovely to 7400 rpm in every gear, flip from 4th to 5th and it drops from 7000 plus to anywhere between 5800-6200 rpm, will sit all day there which is between 60-64mph I guess ( speedo is in giga counter above 40! ) but was hoping it would pull more
What cogs are others running and what are you cruising at in 5th ( either rpm or speed) please
swissdean
Re: Gt186 / cyclone 5 /FDR?
Postby nsaints » Tue Sep 20, 2022 8:02 am
Regardless what the manual says I found my GT186 happiest with a FDR of 5.0
BGM exhaust, 25mm, modified airbox
nsaints
Postby Warkton Tornado No.1 » Tue Sep 20, 2022 10:31 am
From one brief try of a friend's GT186 my impression is of a torquey engine. However, as you say:
"My set up is gt186 ( out of the box), 110/60 crank"
then perhaps port timings remaining as for a 58 mm stroke is the issue here :idea:
Postby Storkfoot » Tue Sep 20, 2022 12:21 pm
I have run many thousands of miles on a GT186 with an MB/bgm Clubman, although more latterly with a Ron Moss Avanti. My final drive has been 4.9 and it is fine. I did once try it with 4.6 but it wouldn’t pull it. That’s always been on a four speed gearbox.
Postby jonw » Tue Sep 20, 2022 2:05 pm
Warkton Tornado No.1 wrote:From one brief try of a friend's GT186 my impression is of a torquey engine. However, as you say:
Modified timings are on the link below.
viewtopic.php?f=7&t=8343&p=72224#p72224
I had a GT186 with GT 60-110 crank, 3mm packer, PM Pipe, 30mm PHBH, 16-47 Pacemaker box which would rev to just over 8K.
Dynod at just over 19hp before I put the 60-110 crank in and it felt stronger after.
It also was happiest at 60 on A roads.
jonw
Postby swissdean » Tue Sep 20, 2022 5:27 pm
Storkfoot wrote:I have run many thousands of miles on a GT186 with an MB/bgm Clubman, although more latterly with a Ron Moss Avanti. My final drive has been 4.9 and it is fine. I did once try it with 4.6 but it wouldn’t pull it. That’s always been on a four speed gearbox.
Funny, that’s exactly what I’m thinking, drop first cog to an 18.. will give it a go when I get back
swissdean
Postby swissdean » Tue Sep 20, 2022 5:28 pm
Yep, that’s two of you saying the same.. mind made up,
swissdean
Postby Toddy » Wed Sep 21, 2022 4:41 pm
Same as Paul running mine on 4.9 li150 46x19 lovely ride
Postby dickie » Wed Sep 21, 2022 5:26 pm
I ran mine initially at 4.7 with ancillotti clubman and 25phbl. I then changed to bgm clubman and phbh30 and it still wasn't happy.
Once I changed to 4.9ish it was MUCH nicer to ride.
Funny what a difference 5% can make, but it does.
That's 3 of us now.
