175 jetting ballpark
Postby a-teamlambretta » Mon Apr 04, 2022 7:24 pm
Motor is an eBay 175 top end using a delloto sh1/20 carb with foam type filter and a scootopia 42 ancilloti .
Choke and idle seems ok as starts and idles ...I have put a 122 main in ...any suggestions on main or Is it in the ballpark.
Cheers Simon
a-teamlambretta
Re: 175 jetting ballpark
Postby dickie » Tue Apr 05, 2022 8:23 pm
A tv175 with sh1/20 has 108 with airbox and standard exhaust, so I'd say you're in the right ball park for the main, but probably a bit rich.
Postby a-teamlambretta » Wed Apr 06, 2022 12:19 pm
dickie wrote:A tv175 with sh1/20 has 108 with airbox and standard exhaust, so I'd say you're in the right ball park for the main, but probably a bit rich.
Thanks....I've removed the foam filter so might be ok .... will do a plug chop or two.
Cheers Simon
a-teamlambretta
Postby hullygully » Wed Apr 06, 2022 2:01 pm
might need to play with pilot bud
200 slide?
