175
175
Postby col1968 » Wed Oct 01, 2014 5:19 am
Hi there i am having a 150 barrel bored out to a 175, please could you advice what carb, manifold and carb settings will be required.It will be running through a standard air box, with a 42mm clubman.Many Thanks Col.
col1968
Re: 175
Postby Rich Oswald » Wed Oct 01, 2014 9:04 am
22mm Jetex with 200 slide, manifold with 150 stud spacings, need to remove baffle from air scoop and possibly remove the narrow neck inside the airbox depending on which one you have.
Re: 175
Postby col1968 » Wed Oct 01, 2014 9:12 am
Thanks Rich
col1968
Users browsing this forum: Baidu [Spider], Google [Bot] and 82 guests
