Exhaust change
Exhaust change
Postby Jeff t » Tue Jan 25, 2022 8:51 pm
Hi running a mugello 198 small block changing the exhaust from Gori to CST3 and going to run with chiselspeed side panel air filter, rest is the same. It’s a PHBH 30mm and was running ok but maybe a bit rich before. I’ve put knew rings in good clean up and the Set-up is 40 slide, 266 atomiser, X7 2nd clip, 120 main and 55 pilot. I was going to leave it and see what it’s like, any different views?
Jeff t
Re: Exhaust change
Postby ULC Soulagent » Wed Jan 26, 2022 8:04 am
Which Gori system was used and that will determine the new or same setup on the cst3 ;)
Re: Exhaust change
Postby hullygully » Wed Jan 26, 2022 10:01 am
just remember tp plug chop bud 8-)
Re: Exhaust change
Postby Storkfoot » Wed Jan 26, 2022 11:34 am
I haven’t used the Chiselspeed filter but I have tried two other types that are similar. Just make sure the foam doesn’t compress too much against the panel. If it does, it won’t allow your carb to breath properly.
Re: Exhaust change
Postby Jeff t » Wed Jan 26, 2022 7:27 pm
I’m not sure but it’s about 5 years old and I got from Rimini, looking on their web site it looks like the SS but not sure if that means anything. Also for some reason I thought it was a sport but other than that nothing else to go on, no emails or order history on their web site.
Jeff t
