AF Clo5e question
AF Clo5e question
Postby TVSi » Wed Dec 29, 2021 4:26 pm
Hi all
I am considering a AF Clo5e gearbox for a new engine build (TS1 230) and I would like to know if you can use an uprated selector spring, I ask because I have a Cyclone in another engine and I was advised to use a soft selector spring. This in turn makes gear selection anything but positive causing me to often find a false neutral so I am a bit wary to give it the beans through the gears. Does the AF box have similar characteristics or is the gear selection more "positive" ?
Also is there anything else with the clo5e that I need to consider?
TVSi
Re: AF Clo5e question
Postby trotsky » Wed Dec 29, 2021 7:26 pm
Hi,
i have the supplied AF spring in my 5 speed box & tbh it's fine. I'm gonna be changing the ratio of my gearing, so while i am in there i'm gonna put the "blue" Casa spring in as i have used these before & i like their weight.
Not too stiff like an MB, but strong enough to give as you say a "positive" selection. As recommended by Scotty who uses them in his race motors.
I hope this helps, Steve.
trotsky
Postby TVSi » Wed Dec 29, 2021 7:59 pm
Thanks Steve
That's good information, so is the Casa spring stronger than the AF spring?
i'll check out the Casa blue spring, thanks
TVSi
Postby TVSi » Thu Dec 30, 2021 10:35 am
Is anyone having any issues with false neutrals with the AF box or do you find it OK?
TVSi
Postby hullygully » Thu Dec 30, 2021 1:15 pm
no false neutrals with any of the 5 x speed boxes bud 8-)
Postby TVSi » Sat Jan 01, 2022 11:52 am
Thanks for your comments and advice, either on here or via PM, its appreciated
wishing you all a happy new.
TVSi
