Need a 2.5mm head gasket.. Source?
Postby Bofs » Wed Oct 20, 2021 11:47 am
Need a 2.5mm head gasket for a SIL 200 66mm barrel.
Been hunting online to no avail. Checked the usual suspects.
Anyone know where I`d get one?
Bofs
Re: Need a 2.5mm head gasket.. Source?
Postby al pushpak » Wed Oct 20, 2021 12:04 pm
Cambridge Lambretta ?
al pushpak
Postby hullygully » Wed Oct 20, 2021 12:45 pm
why not use a 1 + 1.5 to get your thickness, on my gori I have to use 2 head gaskets to get my clearances as it's being top n tailed
Postby shamrockexpress » Wed Oct 20, 2021 9:00 pm
you could use 6 x .5 mm gaskets and take one off that should get you back to 2.5 :mrgreen: :mrgreen: :lol:
shamrockexpress
Postby Cgt75b » Thu Oct 21, 2021 5:48 am
Postby Knowledge » Thu Oct 21, 2021 12:06 pm
Bots, if this is a one off, then why not make your own.
Get a bit of 2.5mm thick Ali and lay an existing gasket on top and overspray with an aerosol paint (ask Birdy for a can, he has loads). When it is dry, take the old gasket off and then remove any alloy from the 2.5mm plate that is painted.
I know you know this stuff, but I put it here just in case this is news to another member.
Postby Bofs » Fri Oct 22, 2021 2:44 pm
hullygully wrote:why not use a 1 + 1.5 to get your thickness, on my gori I have to use 2 head gaskets to get my clearances as it's being top n tailed
Could do but rather have one to minimise blow-out. Yours work fine? No problems?
Bofs
Postby Bofs » Fri Oct 22, 2021 2:45 pm
shamrockexpress wrote:you could use 6 x .5 mm gaskets and take one off that should get you back to 2.5 :mrgreen: :mrgreen: :lol:
Dicko :)
Bofs
Postby Bofs » Fri Oct 22, 2021 2:46 pm
Knowledge wrote:Bots, if this is a one off, then why not make your own.
Yeh last resort, good point though.
Bofs
Postby Bofs » Fri Oct 22, 2021 2:49 pm
Cgt75b wrote:https://www.lambrettaupgrades.co.uk/apps/webstore/products/show/6819783
Spotted those but the idea of a 2.5 step under the head had me worried, mine is 66mm bore. Might only be 2mm around the edge, probably nothing to worry about?
Bofs
Postby Bofs » Fri Oct 22, 2021 4:32 pm
Cheers got some ordered, base packers and head gaskets, all on sale too. Base packers only £3.50 and head gaskets only £3.00!! :D
Bofs
Postby hullygully » Mon Oct 25, 2021 8:47 am
aye no probs bud, used 2 x rb20 head gaskets plus an alloy base
Users browsing this forum: Google [Bot] and 59 guests
