New one on me
New one on me
Postby Scooterlam » Sat Sep 04, 2021 6:34 pm
Real odd ball one
After the French euro I had to swap cards due to the slid key coming loose. Changed all the from old carb into different body.
It did the Spanish euro fine till the 5speed died.
Done lots of bit's and bobs since.
Today I'm going through the bike and thought I'd play with the aircrew setting as it drowns with a filter.
The aircrew is up against the engine mount so not easy to get at
Giving it some thought I'm pretty sure there's never been an aircrew in there.
Pick up has always been clean and only thing I've noticed is a slight rise in egt temps on the gamma at wot.
Question is what changes should I expect when I replace the missing part.
Scooterlam
Re: New one on me
Postby ULC Soulagent » Mon Sep 06, 2021 10:14 am
What’s a Slid key ?
Re: New one on me
Postby duncan1958 » Mon Sep 06, 2021 12:30 pm
ULC Soulagent wrote:What’s a Slid key ?
I am going to have a guess at the pin which stops / guides the slide in the carb body
duncan1958
Re: New one on me
Postby Scooterlam » Sun Sep 12, 2021 3:13 am
Yep, I never knew it was a thing until it came loose,
With no engineering background I figured as a groove is a keyway the bit that fits into in must be a key.
I'm sure there's a technical term for it but it works for me.
Scooterlam
