lofty wrote:webster used to weld up windows in reed pistons apparently.. I always thought this sounded a dodgy and a lot of hassle, but its a (maybe bad) option..
dickie wrote:lofty wrote:webster used to weld up windows in reed pistons apparently.. I always thought this sounded a dodgy and a lot of hassle, but its a (maybe bad) option..
Sounds like a recipe for disaster to me!
vegansydney wrote:Thanks for all suggestions! Much appreciated.
The 66 x 30mm Mugello looks ideal, except is has a boost port cut into it already (picture below). The Scuderia Lambretta Veloce kit has an option for a 30mm CH piston but as they're not widely available yet, I'm uncertain if it also has a boost port cut into it.
Running a reed manifold seems like added work and expense, particular as this will have very tame port timings.
I've also emailed AFR and they said to call. Wish me luck!![]()
