Tractorman wrote:You could drain the tank and measure the fuel as you pour it back in and when the light comes on you will have your answer.
coaster wrote:Hi mate, I have the SIP speedo in one of my scoots which used the same tank float unit bur 'flashes the mileage reading rather than a red light. Totally useless imho as its almost impossibvle to spot on the move. I think it alerts when down to about a litre or so in a standard tank (aabout 2 litres in my longrange tank) but thats very approximate
Warkton Tornado No.1 wrote:Hi Bilko.
I've never had one & nor am I likely to get one. Ha! So where is this going?
The warning light is going to be activated by a switch that becomes operative when fuel is below a certain level. The same principle as a float switch from RS Components, say, which utilises a magnet to send a signal via closure of contacts. Such float switches in their simplest form are not adjustable, other than by varying their position, or height from the bottom of the tank.
Dependent upon the construction of the SIP tap will determine if that, too, can be varied, or fine tuned to make the reserve quantity selectable. But.....has anybody on this Forum done so? Or are you going to be the pioneer?![]()
TBH I was surprised that it's not automatic that ANY fuel tap is dismantled & checked prior to fitting! Remember all of the kerfuffle about Scootopia's tap on this Forum? I may have only fitted two, but it's an item (much like most of the remade components) that should be checked. The couple I had in my grubby hands were spot on but other people had issues. Nonetheless, for ten quid, the product is superb VFM & flows well. Plus, of course, the amount of reserve is selectable, something I always like to have a choice in. Not brow beating you, but can there be a better indicator that fuel is low than the traditional three way tap? The bikes I've ridden with SIP taps start to flicker, but I'd prefer traditional reserve & an analogue dial.
Back to the plot. Somebody should know if & how the SIP tap reserve level 'trigger' can be adjusted, most likely SIP themselves......Shame on them if they don't
Users browsing this forum: Baidu [Spider] and 58 guests
