RT 195 - tips?
RT 195 - tips?
Postby Covboy » Thu Apr 22, 2021 8:49 pm
So I've bitten the bullet and moved away from my tried and trusted GT kits ( i've built 3 x 186 and a 240 and love them) to the RT 195, just for a change....
Its going in my silver special , engine has a "pace maker" gearbox, 16 /46 ( final drive 5.3) but with a 60 /116 crank ( for this crank I had to get a different piston and head needed modifying by MB - top tip - read all the info...!!!! ). It's going to have a 25mm phbl and run through the de-restircted airbox.
Exhaust is a BGM V4.
Static electronic ignition, @ 18 deg.
Looking forward to building it & trying it out...
So my question is - any tips / advice / info ?
What would be the baseline jetting?
Re: RT 195 - tips?
Postby nsaints » Fri Apr 23, 2021 7:06 am
I have an RT195 in my TV
Here’s my setup
Casatronic ignition
Standard GP crank
PHBL 25, GP airbox with swan neck removed, BGM mesh filter
I have a MB flange type manifold which gives good alignment with the airbox, so recommended
BGMV4 exhaust
Stock Li150 gearing, so 5:2 or thereabouts
It’s a great ride, won’t set the world on fire performance wise but it’s a pleasure to ride
My jetting
AQ264
D22 T4
MJ 97
Pilot 50
Choke 70
Float valve 200
I want to take it to Al @ Diablo and get the jetting fine tuned. Sometime this year maybe....
nsaints
Re: RT 195 - tips?
Postby ULC Soulagent » Fri Apr 23, 2021 2:21 pm
Piston ported or Reedvalve version?
Re: RT 195 - tips?
Postby Covboy » Fri Apr 23, 2021 4:26 pm
Hi Shane - its the piston ported version.
Re: RT 195 - tips?
Postby ULC Soulagent » Sat Apr 24, 2021 1:18 pm
Rt 200 reedvalve carb
25 delly
110 main
70 choke
40 slide
58 idle set 2 turns out
D22needle 3rd clip
AQ 266 Atomiser
300 float jet
As stated mines reed valve so you could come down on the idle say 50/52 and also main jet too suit
Sx200 gearing 15/46 4.8fd
Bgm v4 zorst
I’d change rings after being run in or 1000 miles, seems excessive too do that early but I find rings wear very quickly after the initial bedding in. Certainly not the most powerful kit out there but does the job while sipping fuel on a 25 delly ;)
Re: RT 195 - tips?
Postby Covboy » Sat Apr 24, 2021 6:45 pm
Thanks Shane
Looking forward to the build. Might use it for iow.
Re: RT 195 - tips?
Postby Meds » Mon Apr 26, 2021 7:35 am
Rt195 non reed
60x110
30mm delly
Clubman (V3&V4)
Pacemaker box 17x46 giving a final drive around 4.95
I’m more a fuller figured gentleman and it pulls my fat arse around.
Meds
Users browsing this forum: Google [Bot] and 58 guests
