Warkton Tornado No.1 wrote:If i were assembling such an engine, besides the cylinder kit, I would consider the choice of crankshaft, specifically stroke & conrod length. i state that because there are significant advantages to a greater stroke & longer conrod in fine tuning the geometry relevant to port timings & the power characteristics of the engine.
However, presuming that you have gone with the standard format, you need to consider squish, compression ratio & the transfer & exhaust port timings.
i would suggest you put the engine together, omitting the rings & wrist pin circlips & see what you have. Do not fit gaskets & see what you have got.
I never, ever fit head gaskets, but that is up to you. The thing is, IMO it would be great if you 'discover' that you require some form of base packing, say, 2 mm or so. Even if base packing was less, I'd strongly advise that a metal base packing/gasket be used. They not only are reusable, but add some 'integrity' to the build with durability. not forgetting the fact that they serve as templates in transferring (excuse the pun....) port geometry from cylinder to case & vice versa.
With a good petroil proof sealant (NOT blue Hylomar) i would not be too concerned about the lack of wall thickness, especially as any metal base packing/gasket will sit outboard of both faces it is sandwiched between. In my time I have had to go with considerably less wall than you have!
Warkton Tornado No.1 wrote:If I don't suggest that you uprate your crankshaft, then somebody else will!
SIL crankshafts are good for such an engine only if they are re-rodded with a decent bearing. IMO you may as well go for a longer stroke, though whether you will find SIL webs in 60 mm these days, I don't know.
In which case, 61 or 62 mm stroke crankshafts become a tempting consideration. Go for the longest conrod available is my advice. Anything to lower primary compression![]()
There are very good crankshaft builders & hopefully you will receive recommendations. Probably the best is a bed-wetting control freak that was once a friend, but power & money can change people.....
Andy B.L.C. wrote:Would be beyond my means, add to the list, quelle surprise..!. Still in the market for a small block mental barrel mind, just worried that the fuels that we're going to be stitched up with will be pissing on our bonfire...
ULC Soulagent wrote:Decent power from a bolt on kitAndy
I’ve looked into this kit also along with the quattrini 210. As with most Tino’s barrels it will probably need tweaking too make sure all ports are of equal measure( previous experience with imola kits).mine had a 60/110 crank in it which like WK1 has said makes a vast difference.Me personally I would leave the bottom n top end rebuild too a professional tuner. Although it won’t do ur bank balance any good the outcome from it will have you grinning like a Cheshire Cat
Andy B.L.C. wrote:Dunno if this helps... https://youtu.be/uxH6COqZs10
Psychedelicropcircle wrote:I think a standard LI crank won’t handle this power, twisted in a heart beat!
Warkton Tornado No.1 wrote:As a new or stronger crank is a 'given' then the additional costs in terms of money & time for a longer stroke are minimal just to accommodate.
As long as you can assess any necessary additional clearance for the increased stroke & operate a sanding drum in the crankcase, then that would be the only essential machining. Even that can be obviated by speaking to crank builders that will reduce the size of the conrod big end outer diameter!
Then, what have you GOT to do? Select base packing to ensure the correct squish with the chosen stroke/conrod/piston combination.
You don't need to match ports or modify port timings @ this stage. Many of us would, but it would be useful to measure & record timings & then just run the thing!
Inevitably, you will have reduced the transfer & exhaust durations from what the 'optimum' should be @ 58 mm stroke, but so what? Try what you have bought 'as is' & then you can think about what, if anything, you would change & approach the matter with some well learnt knowledge.
Two last pieces of advice. Think about your carburation & select wisely. Don't just follow the herd. Try & incorporate an effective air filter, even if you have to make your own.
Lord-Spanner wrote:Warkton Tornado No.1 wrote:As a new or stronger crank is a 'given' then the additional costs in terms of money & time for a longer stroke are minimal just to accommodate.
Hmmmmm now that sounds like a very good plan so why not, thinking 60mm stroke with a 110mm rod, I do have the tools to sort a little grinding to accommodate a longer stroke crank if need be, better to case grind than grind the rod.
I'm sure some time with a calculator would be close then a little poz or neg on the thickness of base plate and head gasket would get the squish right, though some folk run with out head gaskets don't they?? so is it better with or without or is it dependent on squish measurements?
I might purchase a buzzwangley thing for that or just use the steel timing disc I have, we'll see on that one at a later date though as this will be a long slow process due to the cost of parts many other parts.
As for the carb/filter combo I'm thinking VHSB Delly and dependent on room a nice K&N filter(used these for many years on minis and remote controlled 2 stroke off road cars) If they do one the correct size, all that and I've still got the box to consider, deffo a 5 speed though.
Warkton Tornado No.1 wrote:A head to barrel seal will achieved with a good spigot fit.
Race engine tend to run without gaskets, though not because the CR is not particularly high. Reliability is key. There are various suitable sealants but Loctite & Threebond are popular.
Head gaskets are a risk not worth taking & failure can wreck an engine.
Lord-Spanner wrote:Warkton Tornado No.1 wrote:A head to barrel seal will achieved with a good spigot fit.
I should hope the head to barrel is a good fit after the money it cost me, guessing a gasket is a weak point which could blow at any time causing major issues, I have my eye on the Threebond so will use that on the build, I'm wondering if there is anything I can get or do (to put in place of the base plate) to work out the thickness of the base plate so I don't have to buy to many base plates, but if buying several base plates is the only way then that's what i'll have to do
Warkton Tornado No.1 wrote:Lord-Spanner wrote:Warkton Tornado No.1 wrote:A head to barrel seal will achieved with a good spigot fit.
Fair question. Sometimes I have to remind myself of the loads of stuff I have amassed including base gaskets & packings![]()
However, I usually have a good idea which can be based upon calculation but inevitably, a physical check proves the theory.
Besides Lambretta spares I have 100's of fasteners including M8 washers. They can always be found to be of a set thickness as they are stamped from sheet material such as 1.0 mm, 1.2 mm, 1.6 mm etc. You could cut some in half to fit between barrel & crankcase as packing & with some solder to measure squish get an accurate idea of what base packing is required.
Bear in mind that alloy base packings will compress a tad compared to steel washers, but you should get in the right ball park....
dickie wrote:If you only want a rough idea, it's easy enough to calculate from stroke, rod length and piston crown height. I've assumed you haven't machined either end of the barrel.
Users browsing this forum: Google [Bot] and 57 guests
