Before I re-install the barrel n head I intend on flattening them on some glass using some wet n dry which grade would be the best to use?
Cheers Shane
shane BBoys wrote:Before I re-install the barrel n head I intend on flattening them on some glass using some wet n dry which grade would be the best to use?
Cheers Shane
missing lynx wrote:I would use medium grinding paste
shane BBoys wrote:I did have 1.45 on the 1st build using a 3mm base packer and a .5 head packer no gaskets so hopefully matting both surfaces won’t effect the squish too much! Mark 1 186 muggy 110/60 crank, reed valve.
Cheers Shane.
shane BBoys wrote:Thanks for the advice, I’ll try without the head packer which actually measures .45 if my memory serves me well! How will this effect compression?
Cheers Shane.
