Meds wrote:There are some dangers here that may need consideration
The impact loads on the fork link bush bearings will be pretty High - considering 100kg of Lambretta and 80kg of rider jiggling up and down at quite a rapid rate. The bush spreads the load across it full length, thus lessening the point loading.
I appreciate that Bushes do wear (part of my regular winter checks) - but I’ve not heard of any failing completely - where as failure or collapse of a bearing is a known problem.
So care should be exercised when specifying what bearings are required.
steeleyscoot wrote: Why a UK dealer doesn’t offer the conversion surprises me, same as the tapered bearing conversion than Ian Frankland used to offer for forks?
steeleyscoot wrote:Has anyone got experience of doing the fork link needle roller bearing conversion as offered by West Coast Lambretta?
Wee Mark wrote:Any more info on this conversion please Toot?
