Need a shorter than standard rear shock to get frame/manifold clearance, anyone know if such a thing exists?
Std. Series3 shocks are approx 300, need one 280.
bike grim wrote:Look at the Casa offset cones with flat sided engine bar. Loads more clearance then normal offset cones
https://www.riminilambrettacentre.com/e ... ssati.html
John Deeley wrote:Need a shorter than standard rear shock to get frame/manifold clearance, anyone know if such a thing exists?
John Deeley wrote:Kit is a GT240, problem sorted now.
Took the reed packer off, 4mm less at manifold gave me 25mm at shock.![]()
Never been so grateful for trigonometry.
John Deeley wrote:I've built them before without a packer, was fitting one to see if it made any difference.
