GT200 kit
GT200 kit
Postby paul@darlo » Sat Sep 13, 2014 1:30 pm
I'm thinking of trying one the Richard Taylors big block GT 200 kits. I hope to keep my 25mm PHBL breathing through the air box and AF Clubman. Anyone got experience of these kits. My riding is usually 400-500 miles a weekend, usually motorway miles. I'm looking to be able to cruise at 60 with the ability to be able to go (easily) up to 65 to overtake those pesky wagons. Any thoughts would be much appreciated. cheers Paul
paul@darlo
Re: GT200 kit
Postby terryj » Sat Sep 13, 2014 5:03 pm
terryj
Re: GT200 kit
Postby burnside » Sat Sep 13, 2014 5:29 pm
Great kit, done 1300 miles on mine so far. You can run it with a 25mm carb and AF clubman but not sure if this setup will be too restrictive for those speeds, I could be talking out of my backside though, Richard will be able to give you more advise or Eden who has done 000's of miles on this kit
burnside
Re: GT200 kit
Postby Mr G in NYC » Sat Sep 13, 2014 11:19 pm
Nearly finished putting mine together.....must say that I think a 25mm is too small...
I'm running or at least I'm hoping to be running a 30mm PHBH Dellorto....probably
open mouth with a cyclone 5 speed and a BGM pipe.... fingers crossed for the first
400 miles :shock: As I have a habit of giving it some when I shouldn't :cry:
Edens your man for day to day running of these as he's done a fair old amount of
miles on his ..... good luck and be lucky !! 8-) G.
Re: GT200 kit
Postby Mr G in NYC » Tue Sep 16, 2014 12:47 pm
eden...be interesting to know his jetting on the 25mm ?
Is it the 200 or the 186 kit ?
G.
Re: GT200 kit
Postby Budgie » Tue Sep 16, 2014 4:04 pm
Jetting on my 25 mm carb through air box with gt200 kit and BGM exhaust is
AQ 266 with K22 needle on second notch
For first 400 miles main 102 reduced to 100
And pilot 54 reduced to 50
Plug still has good colour
Will be doing a 250 mile round trip on weekend and will be keeping record of fuel consumption and comparing it with a GT186 with 30 mm carb open mouth and AF Clubman. Think the GT200 will give better economy
Keith
Budgie
Re: GT200 kit
Postby Captain Pugwash » Tue Sep 16, 2014 5:16 pm
Keith
K22 or D22 ?
Captain Pugwash
Re: GT200 kit
Postby Mr G in NYC » Wed Sep 17, 2014 1:41 am
thanks Keith. Yes will be interesting to compare fuel usage.
cheers G.
Re: GT200 kit
Postby Budgie » Wed Sep 17, 2014 5:29 pm
Hi Captain,
Your right it's a D22, glasses must have had dirt on them :D
Budgie
Re: GT200 kit
Postby Mr G in NYC » Thu Sep 25, 2014 6:20 pm
GT200 kit fitted into this old gal.......old engine I managed to blow up on the hi way last year...so
its a good transplant ......Got 40 miles on it and its very smooth so far no issues and I'm running it
on 4% Motul800 fully Synth, and keeping it under 40mph and half throttle for the next 400 miles...
Also fitted a Cyclone box and a AF Race clutch basket(nice bit of kit ). Squish set at 1.5mm, 0.7mm
base gasket used and 0,5 head gasket used, Ign timing is at 17 degrees static.( Shit fuel over here).
Carb is 30mm PHBH with a 55 pilot , X2 needle 2nd notch with shim, 45 slide(rich) AV268 Atomiser,
135 main jet, 300 float needle.....BGM12V IGN and flywheel, and a BGM pro rear shock..+BGM pipe.
Feels very smooth and So far so good........gonna put some further miles on it this weekend . G.
Re: GT200 kit
Postby Nassos » Fri Oct 03, 2014 8:16 am
Ι know that it would too restrictive to use it with a smaller carb.
but a good friend of mine want to make his 200cc scooter a bit more "lively"
but on the other hand since his scooter is a TV200 restored in factory standards (body, color etc) he insists in keeping the airbox and keep also the noise of the exhaust in regular levels.
he understand of course that he will fit a kit and probably get much less of the max power. but he only needs to improve the performance of his 200cc cylinder and have a quicker scooter.
so, to make the long story short... do you feel that it would be possible to have this GT200 kit with a GP exhaust and a smaller carb (ie. PHBL25) so to keep the standard look with the airbox and keep the noise of the exhaust in low levels?
Would it be in any case much more improved than a standard set up ?
Nassos
Re: GT200 kit
Postby burnside » Sat Oct 04, 2014 10:53 am
You can run the kit with a 25mm Delly through the airbox, this is one of the options that Rich Taylor offers, along with a clubman exhaust and I would imagine this would still be an improvement on a standard setup
burnside
Re: GT200 kit
Postby Mr G in NYC » Sat Oct 04, 2014 3:00 pm
Got about 50 miles on this kit last weekend........kept it under 40 and half throttle.... raining
today and I'm jet lagged from return London trip :( But tomorrow I'll throw another 50 miles
on it ....so far so good :D ;) G.
Re: GT200 kit
Postby Mr G in NYC » Sun Oct 12, 2014 5:29 pm
Quick 40 miles at 36-44 MPH . 4%. Good run nice weather ....Kit feels good. G
Re: GT200 kit
Postby Mr G in NYC » Wed Oct 15, 2014 2:57 am
About 200 now. Another 50 + this next weekend ...weather permitting 8-)
Feels like it really wants to go :D I'm really digging the 5 speed on this kit.
G
Re: GT200 kit
Postby mainstand » Wed Oct 15, 2014 12:11 pm
400 Miles? Is this your running in period mileage wise?
mainstand
Re: GT200 kit
Postby Mr G in NYC » Wed Oct 15, 2014 2:08 pm
I 'm thinking 400 miles around 40'ish.......then another 200 between 40-50
and another 200 up to 55mph...then 100 under 60mph and then 100 at 3%
up 65mph. Then the open road 8-) .
I usually run them cautiously for 100miles then thrash 'em and hole them or seize
them .....so this will be the first engine I've run in properly :shock: :lol: G.
Re: GT200 kit
Postby mainstand » Wed Oct 15, 2014 3:16 pm
I'm running in a newly born old skool ported 225. Done 118 miles since Sunday at 30, reccomended I do 250 at this speed, then another 250 at 40, then 250 at no more than 50, then not to be held flat out for long periods...all before next Thursday before leaving the south coast for Bridlington. :D
mainstand
Re: GT200 kit
Postby Mr G in NYC » Thu Oct 16, 2014 3:32 am
Sound ..good luck with that. 8-) G.
Re: GT200 kit
Postby burnside » Fri Oct 17, 2014 1:35 pm
Sounds like you are being very cautious running in this kit Mr G. With mine I took it easy and on 4% mix for the 1st 100 miles, but still took it up through the rev ranges, and then for the next 250 miles just made sure that I didn't keep it at over 3/4 throttle for more than a few seconds but still did a couple of longish runs at around the 50-55mph range. After that I rode it like I stole it and no issues :D
burnside
